I’m trying to unravel the possible mess I made with contacts in eM Client. I originally imported all my contacts from Outlook into the Local folders on eM Client. I was able to retain the Categories and Groups I had setup. But then I discovered I couldn’t easily sync with my iPhone (at least not bi-directionally). I have now started syncing my iPhone Contacts to the iCloud and added my iCloud as an account in eM Client for contacts. Now in my contacts bar in the left nav bar I see my local folders and, separately, my iCloud contacts. I have 3 questions.
Should I somehow be syncing these (e.g. should the iCloud contacts “import” onto my local folder) or do I just abandon the local folder and work with eM Client as simply an interface to the contact list stored on the server?
My 2 lists (the local list and the contacts from my iPhone now on iCloud) are slightly out of sync. Any easy way to sort by most recently modified contacts or something so I can manually get all the changes from one place into the other to start using whichever answer comes from #1 above?
In the iCloud set of entries I can’t see groups or categories so no way to just view my contacts except in one big lump. If the answer to #1 is to abandon the local folder and just work with the iCloud set of contacts, I really need a way to view the groups/categories so I can limit what I see.
