Hi there,
I recently shifted from Thunderbird to Em Client.
I wanted to know if there is a way to import email rules automatically ?
As I have a bunch of rules, it would have been very useful .
Thanks and regards
Unfortunately not.
Because of so many variables and because the implementation of Filters in Thunderbird is somewhat different to Rules in eM Client, it is not possible to import them.
Thanks for your quick reply Gary.
I do understand. I thought I was worth checking, just in case
Regards
I have almost 300 filtes. If there is not import function in emclient, it means that a move to emclient from thunderbird is not possible. Or is there a workaround known by today?
Unfortunately not.
Because of so many variables and because the implementation of Message Filters in Thunderbird is somewhat different to Rules in eM Client, it is not possible to import them.
Why is this not on the feature list for emclient? Import from thunderbird should be top prio to convince user to switch to emclient.
Why are incompatible items not compatible? Maybe that is a question that is too deep to be asked on a forum like this.
