Hotmail not working
Starting around September 1, my Hotmail account no longer works with Emclient.  It will not synchronize any of the folders–they are all completely empty.  I can still access my account through live.com.  Did Microsoft change something recently to cause this?  If anyone can give me any help with this, I would appreciate it.
I am running Win10, eMClient 6.0.24928.0.
I have got the same problem. Tried reinstalling the account without succes, seems like outlokk is blocking it…
Has your hotmail account been migrated to the new Microsoft Exchanger server?
To find out if Microsoft has migrated your account yet - in a Browser, login to your account at outlook.com. When your mailbox has been migrated to the new infrastructure, the top left corner will show Outlook Mail. When your account hasn’t been migrated yet, it will show Outlook.com.
If it shows Outlook Mail , you need to set up your account in EM client as an Exchange account. iMAP will still work, but not as well as Exchange (also Calendar and Contacts are not synced with iMAP).  An EM Client  Outlook account (ie using AirSync)will no longer work.
Note that when you set up an Exchange account, EM Client can take quite a few minutes to obtain the server details.
See this relevant doco
https://drive.google.com/open?id=0B8ey_8poDxPUQV85WmU3bjNobVk
Thank you, that took care of the problem for me.
Solved mine too! Now I have got a problem with a message showing up that my kontacts arent synchonising. How to solve that?
Contacts will only sync if you use the Exchange protocol, not imap
When re-installing eM Client 6 I skip auto setup. Then I click on MAIL and select EXCHANGE. Enter [email protected] and password. Takes several minutes then error message is that my login credentials are not working. ANy suggestions???
Thanks - this seems to work.
Try version 7
Version 7 does not support the importation of Outlooks “storage folders” correctly as previously
acknowledged by eM Client support.
I was getting stuck with this same problem until I realized the “User Name” needs to be the e-mail address, not your real name. Now it works. Thanks!
Can You reupload pls?
https://mega.nz/file/V6gTjYoZ#jxutSZYPfSjfNRFoiSOroBozoOG90C8pH-xSqfTfAX4
It may be safer to download any previous version from the official Release History.
If I log on to Outlook. It show “Orange exclamation”
But when I try to log on to Exchange, does not finish a sign, still shows this table
I have the same problem - my hotmail account stopped syncing a few days ago so I deleted it and now trying to add it again using the ‘Exchange’ option but even though my password was accepted I still get the login box popup every time I click ‘Finish’.
I am stuck in a loop with this when I click finish.
Are you trying to sign in to eM Client?
Only continue if you downloaded the app from a store or website that you trust.
You cannot setup a free Hotmail/Outlook.com email account as Exchange using oAuth. That is why the oAuth token is never issued and you can’t continue.
This is a restriction on the Exchange server.
It was initially setup the other way and had been working fine until the last few days when it quit working.
That is being discussed in another topic: Not receiving Outlook emails
