get this message when i try to download update? ( "“eM_Client_v7.2.37929.msi” is an executable file. Executable files may contain viruses or other malicious code that could harm your computer. Use caution when opening this file. Are you sure you want to launch “eM_Client_v7.2.37929.msi”) my question is cause im not to techy lol is do i download? or should i ask em to send me updates in a different file? thnx for any and all input
It will be fine. Your browser will give you the same message with any executable file you try to download.
But if you are unsure, download the file then run your anti-virus application on it before installing.
thank u i will do that
