Help... continual crash
pops up a reminder (for a meeting) and anything i try to do (dismiss, hide, etc.) - crashes eM… What gives?  Any thoughts?
Hi Ken. Not sure what the cause may be but if it is just for one event, deleting it may solve the crashing problem.
Ignore the pop-up and go to the Calendar tab, select and delete the event, and restart eM Client.
Great idea!  Tred it … and guess what?  It crashed eM when I tried to delete it!!!
This is crazy!
If the calendar is an online one, you could remove the event through the web interface for the account. Or even remove the account from eM Client then add it again. Maybe reloading it from scratch will solve the problem.
If it is a local calendar, that will be a bit more difficult.
