How to set up email received so" lastest received is listed at top"
Why can’t I down load latest updates? Tried from notification and refered to your website but still can not download
Thanks
Click on the column heading for the Received date/time. Click a second time if necessary so the little triangle indicator is pointing down. If you don’t have the Received column, right-click on the column headings and select “Columns Configuration” and select it.
Mike
what version are you currently using?
