Windows 10U 64 bit up to date – Email AOL. – eM version 7.2.349559.0
“error value was either too large or too small for an int32”
Norman , I have a similar problem . I use 2 PC’s with the same account , one PC gives this error when sync a Yahoo account the othe PC Sync’s ok … Did you find a fix
22:08:15 System.OverflowException: Value was either too large or too small for a UInt32.
Regards Trevor
I went on AOL website and deleted 3 old emails that I had already deleted using eM. It appears to work OK now.
The above did NOT work
Hello, this issue should be workarounded (because it is primarily a new bug on Yahoo servers) in the version 7.2.38732. You can download it here:
https://www.emclient.com/dist/v7.2.38732/setup.msi
Hi , In the end I had to reinstall emclient as my second pc seemed to run the account without issues , thanks for your reply
