This is the error message I get, can anybody help?
Thanks!
System.BadImageFormatException: Could not load file or assembly ‘System.Data, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089’ or one of its dependencies. The file or directory is corrupted and unreadable. (Exception from HRESULT: 0x80070570)
File name: ‘System.Data, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089’ —> System.BadImageFormatException: Could not load file or assembly ‘System.Data, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089’ or one of its dependencies. The file or directory is corrupted and unreadable. (Exception from HRESULT: 0x80070570)
File name: ‘System.Data, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089’
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
