Can’t start eM Client this morning.
First part of error reads:
System.ArgumentOutOfRangeException: Year, Month, and Day parameters describe an un-representable DateTime.
Just wondering if it’s because it’s 29th February.
Doing a bit of trouble shooting here. Found that if I re-set my system date to 28th Feb, eM Client will open normally.
Have changed date back to 29th Feb and eM Client remains open. Not sure if everything is working properly, but I have my fingers crossed.
Thanks, that fixed mine!
I followed this and it worked for me… I changed system date to 28th, open the app, changed back to 29th. Now it won’t crash again when start.
Same problem
I played a bit with the problem. So the workaround (only today) will be like this.
This method should work in most cases, but do not set the calender view to monthly or other view for today. Next day em client will be fine.
Ok this metod work for me.
hmm this does not solve the problem for me…
Any other ideas?
tnx.
Same with me - the problem is February 29th
there is a bug in the month view of the program that manifested with the leap year.
This update should fix the issue: http://www.emclient.com/dist/v6.0.249…
Thanks, Olivia, I looked further into my issue, and now I think Im not experiencing the same bug as described above.
I have tried the work around described above, but it didnt work.
Also I have a crash due to a timezone error, not due to the leap year thing.
So I think it’s something different.
cheers. Bart
This method also works with the Beta version. Thank you Johnny Loh!
Olivia when will there be an updated Beta version with the fix?
Thank you!
Hi Eric,
we’re working on the fix on BETA, we’ll try to finish it as soon as possible.
Perform the following steps.
Exit eM.
Set your system date to February 28.
Start eM.
GO to Calendar and select ANY view except Month view. I prefer Week view.
GO back to mail.
Exit eM.
Reset system date to February 29.
Start eM.
Everything should work but do NOT go to Month view. It will immediately experience an application error.
Hope this helps.
