Marcin1
September 7, 2018, 7:12am
1
Hi
I need little help with drag&drop feature. It’s not working for me. I can’t attach any file, just by draging it from desktop or any other place into my composed mail. Is this natural in this client? I was looking everywhere in settings, forums. There are some old topics about it, but without clear answer.
Thanks (and sorry for my eng)
Gary
September 7, 2018, 10:32am
2
As far as I can see, dragging a file from Windows Explorer to the compose window works as it should.
What version of eM Client are you using Marcin?
Gary
September 7, 2018, 12:18pm
4
I tried it again, and it works.
I open a new message window and type some text. Then I open Windows explorer and drag a file to the new message window. It is now an attachment.
Are you doing anything different?
Marcin1
September 7, 2018, 12:21pm
5
Same as you…
My computer is connected to domain, could it be a reason?
Do You maybe run eM Client elevated (as Administrator)? Explorer run with standard level, which means no drag&drop to elevated app.
Marcin1
September 7, 2018, 12:38pm
7
To jest to Sylwester. Nie zauważyłem, że odpala się w taki sposób. Dziękuję.
This is it Sylwester. I did not notice that the program starts in Administrator mode. Than you!
Glad to see resolved problem ;-).
Jan_K
June 27, 2019, 2:11pm
9
THANK YOU, THANK YOU SO MUCH!
I’ve found em client to be perfect but switched to other inferior client because I couldn’t fix this! thank you!1!!
