Clipboard is possible to use by Ctrl+C and Ctrl+V everywhere. Ctrl+Insert and Shift+Insert is also working while composing the body. But in the header it does not work.
It is rather uncomfortable if someone is used to these hotkeys.
For example I want to copy an address from the To field to Cc. Therefore I select an address from the To field, press Ctrl+Insert, Delete (supposing the address to be on the clipboard), focusing Cc field and press Shift Insert. Nothing is happening. I remember I should use Ctrl+V instead of Shift+Insert. But Shift+Insert pastes not the email address but something different which was on the clipboard previously.
So I have to go back to the To field, undo deleting, select again, pressing Ctrl+X, Tab, and Ctrl+V.
OK, it is not too much time but if Your habits are too strong then it is annoying.
Please, make Ctrl+Insert and Shift+Insert available in the header fields. Thanks.
