Received this hard crash today when testing incoming mail behaviour. Seems to be related to AC3Filter, as it occurred right when the message came in (presumably, to play the notification .wav):
Problem Event Name: APPCRASH
Application Name: MailClient.exe
Application Version: 5.0.17263.0
Application Timestamp: 50cb3ef1
Fault Module Name: ac3filter.ax_unloaded
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 4fde1df8
Exception Code: c000001d
Exception Offset: 2e470002
OS Version: 6.2.9200.2.0.0.256.48
Locale ID: 1033
Could be an AC3filter-issue only, so I apologize if that’s the case. Going to try and look into it more though. Windows 8 RTM per the OS Version above.
Thanks!
