I have imported a WebEx calendar ICS file to my eM Client LOCAL calendar, which works perfectly. I can see it on my calendar. If I double-click it or right-click, select Open - eM Client crashes.
Manually entered calendar entries work fine and so do other imported ICS entries. I can delete the entry also.
eM Client is 7.2.34711.0 on Windows 10. The exception shows System.Reflection.TargetInvocationException
Does anyone have any ideas on how to overcome this issue? Thanks in advance for any help!
