My google reminders keep popping up after i do a Dismiss All. I will dismiss these 2 reminders that pop up and then a few seconds later they will pop up again. How can I get that to stop happening?
what version of eM Client are you using?
I also get this problem, and I’m on 6.0.22344.0. I’m guessing that since this is a question from two years ago, this is probably not eM Client, but a failure of the server to recognize the notification dismissal?
I’m also fed up with reminders but wish to maintain my Google Calendar. Cannot this feature be turned off?
Merry Christmas! (Oops, that was a reminder!)
Hi Knocke,
you should be able to disable reminders for separate events or right-click the calendar folder under your account and choose Properties.
In the general tab you should be able to uncheck the option to ‘Show reminders’.
Hi, I’m on version 7.0.30068.0. My reminders refuse to be dismissed. I have followed all steps to turn reminders OFF, but I still cannot dismiss ANY reminders, even ones that are over 100 days overdue!! This is seriously annoying and I can’t find ANY forum entry that actually solves this issue!! How can one fix this for good?
I’m on version 7.1.30794.0. I can’t turn off reminders. After clicking on “dismiss” in the upper right corner, the reminder appears again. I’ve repeated it for 20-30 times.
Cheers Roland
Did anyone ever find out how to resolve this properly? I would like to get reminders, but not the same reminders that cannot be dismissed!
Thanks,
- Jason
Got this problem too - the reminders just refuse to be dismissed; Ver. 7.2.35595.0
The only way is to remove the reminders altogether, but this kind of ruins an important part of Calendar functionality.
Please advise
Clem
I’m plagued by this bug as well. What’s the point of having reminders if we have to remove them? LOL!
Adam.
The same problem here. It’s just the shame for program pretended to be a full-functioned e-mail client/
Fortunately I don’t have that problem and the reminders are dismissed when I dismiss them. Maybe it is a bug that some experience, but it is not a general issue.
What version of eM Client are you using?
And how is this not a full-functioned email client Andrey?
@Gary Curtin, an email client which respects itself and comes with calendar option cannot allow itself to show 20 years old-fashioned modal dialogs as a reminder. And moreover - PREVENT these dialogs from being closed.
Maybe you could download a more recent version from the Release History as I certainly don’t see “20 years old-fashioned” dialogues in the version I am using.
But anyway, as I said, I don’t think that the issue you are having is the norm Andrey. If you have a Pro License, please open a support ticket directly with eM Client. They will be able to assist you further.
I meant using modal dialogs for reminders. And the version I have is the most recent one. I have no Pro License - I am just seeking for a good e-mail client while trying various programs. I liked eM Client, but that issue with reminders, unfortunately, prevents me from using it.
It is ironic though, isn’t it, that calendaring is the cause for abandoning an email client.
I have the same problem. I have even deleted the Event from my Calendar, but Reminver of it still pops up??
