We had a similar issue in the Windows version some time back. The message list was scrolling too quickly with touch pads. It was fixed after submitting a support ticket.
If you have a Pro License, please submit a ticket, otherwise hopefully eM Client will read this and take some action to correct the behavior in a later release.
The trackpad settings are correct for every other program on the computer, I don’t feel like correcting them for one program and making them wrong for everything else.
Thanks for your response.
Actually I was afraid of that, but since you didn’t mention it,
it might have been a solution.
But I can certainly see your point…
Next is only a “compromize” setting for the trackpad or as you asked.
an adjustment of eM Client how it perceives the output of the trackpad.
I’m almost sure that other MacBook Pro users have the same experience.
As I said before, we had a similar issue on Windows. It was working OK in other Windows applications and most of eM Client. Just in the message list it was scrolling too fast. And only with the touch pad; with a mouse it was fine.
If that is a similar situation you are having Philip, then there is nothing you can do except wait for eM Client to fix it.
