hello!
make a separate button - send again!
Often it is required to send the letter again, edit the sender, edit the text of the already sent letter.
- so that when you click the send button again, the same letter opens, where you can edit the contents of the letter and the sender (the field to which should not be empty, there should be a previous sender)
- add menu EDIT AS NEW(or menu send again) - right button any letter - the same letter opens, where you can edit the contents of the letter and the sender (the field to which should not be empty, there should be a previous sender)
