Just a heads-up to the dev team.
AVAST version 8 released within the last day or so seems to be causing problems with IMAP accounts.
I’ll investigate more tomorrow.
You might to post what is the message you receive as that will assist support better.
I know…
Updated AVAST to version 8 and eM Client starts to complain that the IMAP account settings are wrong as it can’t connect.
Disable AVAST shields and the same message appears.
Experiment with the SSL settings in eM Client but still no joy.
Uninstall AVAST and everything works.
I had this problem with Kaspersky. After a while I realised it was only happening on SSL connections. I changed the Kaspersky settings to ignore network traffic from emClient and the problem went away.
Of course this was after a while talking to the guys at emClient and checking logs, etc.
Good luck!
For gmail and Avast 8:
IMAP Port 993, Use SSL/TLS on special port (legacy)
SMTP Port 465, Use SSL/TLS on special port (legacy)
Both - User identity credentials
(I got stuck on this until I picked the ‘legacy’ option
If you upgraded from Avast 7 make sure you do not still have the SSL settings set up in the email shield. I had to delete them when I upgraded. I don’t have any problems now with gmail in eM Client and using Avast 8.
Avast mail shield on crashes Em client on my system, turned off: no problems
fvbeers: If you turn the mail shield off you might not be protected anymore. In Avast V8.0.1489 I have it on and “Scan SSL connections” is checked - which now in Avast will still check your email regardless of SSL/STS checks in eM Client. For gmail, in em Client I needed to set IMAP and SMTP to the “legacy” port options to get it working - see previous post. That’s in Tools->Accounts, IMAP and SMTP tabs, Security policy dropdown box. If not gmail, you may need to change these per your mail service requirements.
thanks for the info, I’ll try that and report!
not working with SMTP, restored settings error:
eM Client for SoftMaker (5.0.17399.0)
Windows: Microsoft Windows NT 6.2.9200.0, Framework: 2.0.50727.6407
System.ArgumentOutOfRangeException: Het opgegeven argument ligt buiten het bereik van geldige waarden.
Parameternaam: name
bij MailClient.Storage.Data.SQLite.DbMailRepository.SetPartContent(IMailRepositoryItem item, String name, Stream content, Boolean encoded)
bij MailClient.Imap.Synchronizer.Fetch(Folder folder, FetchNotification response)
bij MailClient.Imap.Synchronizer.ImapNotification(ConnectionPoolEntry connectionPoolEntry, Folder activeFolder, NotificationEventArgs e)
bij MailClient.Imap.ConnectionPoolEntry.Connection_Notification(Object sender, NotificationEventArgs e)
bij MailClient.Imap.Base.Connection.ParseUntagged(String line)
bij MailClient.Imap.Base.Connection.ParseReply(String line)
bij MailClient.Imap.Base.Connection.ReceiveWorker()
bij System.Threading.ThreadHelper.ThreadStart_Context(Object state)
bij System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
bij System.Threading.ThreadHelper.ThreadStart()
5.0.17399.0
false
2.0.50727.6407
Parameternaam: name
MailClient
MailClient.exe
100684505
MailClient
SetPartContent
MailClient
MailClient.Storage.Data.IMailRepositoryItem
item
mscorlib
System.String
name
mscorlib
System.IO.Stream
content
mscorlib
System.Boolean
encoded
7a
369
MailClient.exe
100667543
MailClient
Fetch
MailClient
MailClient.Storage.Application.Folder
folder
MailClient.Imap.Base.FetchNotification
response
5bd
eb2
MailClient.exe
100667529
MailClient
ImapNotification
MailClient
connectionPoolEntry
MailClient
activeFolder
MailClient.Imap.Base.NotificationEventArgs
e
30c
4f2
MailClient.exe
100689819
MailClient
mscorlib
System.Object
sender
e
11d
214
MailClient.Imap.Base.dll
100663349
ParseUntagged
mscorlib
System.String
line
3f
5e
100663352
ParseReply
mscorlib
System.String
line
e4
1c8
100663347
ReceiveWorker
11
52
mscorlib.dll
100668076
mscorlib
ThreadStart_Context
mscorlib
System.Object
state
14
65
mscorlib.dll
100667883
mscorlib
Run
mscorlib
executionContext
mscorlib
System.Threading.ContextCallback
callback
mscorlib
System.Object
state
58
6e
mscorlib.dll
100668078
mscorlib
ThreadStart
8
43
/ACCOUNT:2/Inbox
* 1165 FETCH (UID 19096 MODSEQ (1666394) BODY[2.HEADER] NIL BODY[2.1.MIME] {89}
* OK Gimap ready for requests from 86.86.94.101 f44if1154307eep.178
MailClient.exe
C:\Program Files (x86)\SoftMaker Office Professional 2012\eM Client\MailClient.exe
MailClient.exe
MailClient.exe
5.0.17399.0
eM Client
eM Client
5.0.17399.0
False
False
False
False
False
Taalonafhankelijk
ntdll.dll
C:\Windows\SYSTEM32\ntdll.dll
ntdll.dll
ntdll.dll.mui
6.2.9200.16384 (win8_rtm.120725-1247)
DLL-bestand voor NT-laag
Microsoft® Windows®-besturingssysteem
6.2.9200.16384
False
False
False
False
False
Nederlands (Nederland)
snxhk.dll
C:\Program Files\AVAST Software\Avast\snxhk.dll
snxhk
snxhk.dll
8.0.1489.300
avast! snxhk
avast! Antivirus
8.0.1489.300
False
False
False
False
False
Taalonafhankelijk
KERNEL32.dll
C:\Windows\SYSTEM32\KERNEL32.dll
kernel32
kernel32
DLL-bestand voor Windows NT BASE API-client
Besturingssysteem Microsoft® Windows®
6.2.9200.16384
False
False
False
False
False
KERNELBASE.dll
C:\Windows\SYSTEM32\KERNELBASE.dll
Kernelbase.dll
Kernelbase.dll.mui
6.2.9200.16384
False
False
False
False
False
MSCOREE.DLL
C:\Windows\SYSTEM32\MSCOREE.DLL
mscoree.dll
mscoree.dll
4.0.41209.0 (Main.041209-0000)
Microsoft .NET Runtime Execution Engine
Microsoft® .NET Framework
4.0.41209.0
False
False
False
True
False
Engels (Verenigde Staten)
ADVAPI32.dll
C:\Windows\SYSTEM32\ADVAPI32.dll
advapi32.dll
advapi32.dll.mui
Geavanceerde Windows 32 basis-API
6.2.9200.16384
False
False
False
False
False
msvcrt.dll
C:\Windows\SYSTEM32\msvcrt.dll
msvcrt.dll
msvcrt.dll
7.0.9200.16384 (win8_rtm.120725-1247)
Windows NT CRT DLL
Microsoft® Windows® Operating System
7.0.9200.16384
False
False
False
False
False
sechost.dll
C:\Windows\SYSTEM32\sechost.dll
sechost.dll
sechost.dll.mui
Host for SCM/SDDL/LSA Lookup APIs
6.2.9200.16384
False
False
False
False
False
RPCRT4.dll
C:\Windows\SYSTEM32\RPCRT4.dll
rpcrt4.dll
rpcrt4.dll.mui
Runtime voor RPC (Remote Procedure Call)
6.2.9200.16384
False
False
False
False
False
SspiCli.dll
C:\Windows\SYSTEM32\SspiCli.dll
security.dll
security.dll
6.2.9200.16420 (win8_gdr.120919-1813)
Security Support Provider Interface
6.2.9200.16420
False
False
False
False
False
CRYPTBASE.dll
C:\Windows\SYSTEM32\CRYPTBASE.dll
cryptbase.dll
cryptbase.dll
Base cryptographic API DLL
6.2.9200.16384
False
False
False
False
False
bcryptPrimitives.dll
C:\Windows\SYSTEM32\bcryptPrimitives.dll
bcryptprimitives.dll
Windows Cryptographic Primitives Library
6.2.9200.16384
False
False
False
False
False
mscoreei.dll
C:\Windows\Microsoft.NET\Framework\v4.0.30319\mscoreei.dll
mscoreei.dll
mscoreei.dll
4.0.30319.18010 built by: FX45RTMGDR
4.0.30319.18010
False
False
False
True
False
SHLWAPI.dll
C:\Windows\SYSTEM32\SHLWAPI.dll
SHLWAPI
SHLWAPI.DLL.MUI
Shell lichtgewicht hulpprogrammabibliotheek
6.2.9200.16384
False
False
False
False
False
USER32.dll
C:\Windows\SYSTEM32\USER32.dll
user32
user32
DLL-bestand voor Windows USER API-client (meerdere gebruikers)
6.2.9200.16384
False
False
False
False
False
GDI32.dll
C:\Windows\SYSTEM32\GDI32.dll
gdi32
gdi32
6.2.9200.16622 (win8_gdr.130523-1504)
GDI Client DLL
6.2.9200.16622
False
False
False
False
False
IMM32.DLL
C:\Windows\system32\IMM32.DLL
imm32
imm32
Multi-User Windows IMM32 API Client DLL
6.2.9200.16384
False
False
False
False
False
MSCTF.dll
C:\Windows\SYSTEM32\MSCTF.dll
MSCTF
MSCTF.DLL.MUI
DLL-bestand voor MSCTF-server
6.2.9200.16384
False
False
False
False
False
mscorwks.dll
C:\Windows\Microsoft.NET\Framework\v2.0.50727\mscorwks.dll
mscorwks.dll
mscorwks.dll
2.0.50727.6407 (Win8RTMGDR.050727-6400)
Microsoft .NET Runtime Common Language Runtime - WorkStation
2.0.50727.6407
False
False
False
False
False
MSVCR80.dll
C:\Windows\WinSxS\x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.6910_none_d089c358442de345\MSVCR80.dll
MSVCR80.DLL
MSVCR80.DLL
8.00.50727.6910
Microsoft® C Runtime Library
Microsoft® Visual Studio® 2005
8.00.50727.6910
False
False
False
False
False
shell32.dll
C:\Windows\SYSTEM32\shell32.dll
SHELL32
SHELL32.DLL.MUI
6.2.9200.16496 (win8_gdr.130108-1504)
Gemeenschappelijk DLL-bestand van Windows Shell
6.2.9200.16496
False
False
False
False
False
combase.dll
C:\Windows\SYSTEM32\combase.dll
COMBASE.DLL
COMBASE.DLL.MUI
Microsoft COM voor Windows
6.2.9200.16384
False
False
False
False
False
SHCORE.dll
C:\Windows\SYSTEM32\SHCORE.dll
SHCORE
SHCORE.dll.mui
SHCORE
6.2.9200.16384
False
False
False
False
False
profapi.dll
C:\Windows\SYSTEM32\profapi.dll
PROFAPI.DLL
PROFAPI.DLL
User Profile Basic API
6.2.9200.16384
False
False
False
False
False
mscorlib.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\mscorlib\d1ce70bf6cbab6ab838cbd8b50e902c1\mscorlib.ni.dll
mscorlib.dll
mscorlib.dll
Microsoft Common Language Runtime Class Library
2.0.50727.6407
False
False
False
False
False
mscorsec.dll
C:\Windows\Microsoft.NET\Framework\v2.0.50727\mscorsec.dll
mscorsec.dll
mscorsec.dll
2.0.50727.6387 (Win8RTM.050727-6300)
Microsoft .NET Security module
2.0.50727.6387
False
False
False
False
False
WINTRUST.dll
C:\Windows\SYSTEM32\WINTRUST.dll
WINTRUST.DLL
WINTRUST.DLL
6.2.9200.16666 (win8_gdr.130712-1604)
Microsoft Trust Verification APIs
6.2.9200.16666
False
False
False
False
False
CRYPT32.dll
C:\Windows\SYSTEM32\CRYPT32.dll
CRYPT32.DLL
CRYPT32.DLL.MUI
Crypto-API32
6.2.9200.16666
False
False
False
False
False
COMCTL32.dll
C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_5.82.9200.16384_none_bf100cd445f4d954\COMCTL32.dll
COMCTL32
COMCTL32.DLL.MUI
5.82 (win8_rtm.120725-1247)
Bibliotheek met algemene elementen
6.2.9200.16384
False
False
False
False
False
MSASN1.dll
C:\Windows\SYSTEM32\MSASN1.dll
msasn1.dll
msasn1.dll
ASN.1 Runtime APIs
6.2.9200.16384
False
False
False
False
False
CRYPTSP.dll
C:\Windows\SYSTEM32\CRYPTSP.dll
cryptsp.dll
cryptsp.dll
Cryptographic Service Provider API
6.2.9200.16384
False
False
False
False
False
rsaenh.dll
C:\Windows\system32\rsaenh.dll
rsaenh.dll
rsaenh.dll
6.2.9200.16553 (win8_gdr.130308-1505)
Microsoft Enhanced Cryptographic Provider
6.2.9200.16553
False
False
False
False
False
imagehlp.dll
C:\Windows\SYSTEM32\imagehlp.dll
IMAGEHLP.DLL
IMAGEHLP.DLL
Windows NT Image Helper
6.2.9200.16384
False
False
False
False
False
ncrypt.dll
C:\Windows\SYSTEM32\ncrypt.dll
ncrypt.dll
ncrypt.dll.mui
Windows NCrypt Router
6.2.9200.16384
False
False
False
False
False
bcrypt.dll
C:\Windows\SYSTEM32\bcrypt.dll
bcrypt.dll
bcrypt.dll.mui
Windows-bibliotheek van cryptografische primitieven
6.2.9200.16384
False
False
False
False
False
NTASN1.dll
C:\Windows\SYSTEM32\NTASN1.dll
ntasn1.dll
ntasn1.dll.mui
Microsoft ASN.1 API
6.2.9200.16384
False
False
False
False
False
gpapi.dll
C:\Windows\SYSTEM32\gpapi.dll
gpapi.dll
gpapi.dll.mui
API voor Groepsbeleidclient
6.2.9200.16384
False
False
False
False
False
cryptnet.dll
C:\Windows\SYSTEM32\cryptnet.dll
CRYPTNET.DLL
CRYPTNET.DLL
6.2.9200.16592 (win8_gdr.130419-1503)
Crypto Network Related API
6.2.9200.16592
False
False
False
False
False
WLDAP32.dll
C:\Windows\SYSTEM32\WLDAP32.dll
WLDAP32.DLL
WLDAP32.DLL.MUI
Win32 LDAP API DLL
6.2.9200.16384
False
False
False
False
False
IPHLPAPI.DLL
C:\Windows\SYSTEM32\IPHLPAPI.DLL
iphlpapi.dll
iphlpapi.dll.mui
IP-helper-API
6.2.9200.16384
False
False
False
False
False
NSI.dll
C:\Windows\SYSTEM32\NSI.dll
nsi.dll
nsi.dll
NSI User-mode interface DLL
6.2.9200.16384
False
False
False
False
False
WINNSI.DLL
C:\Windows\SYSTEM32\WINNSI.DLL
winnsi.dll
winnsi.dll
Network Store Information RPC interface
6.2.9200.16384
False
False
False
False
False
ole32.dll
C:\Windows\SYSTEM32\ole32.dll
OLE32.DLL
OLE32.DLL.MUI
Microsoft OLE voor Windows
6.2.9200.16384
False
False
False
False
False
uxtheme.dll
C:\Windows\system32\uxtheme.dll
UxTheme.dll
UxTheme.dll.mui
DLL-bestand Microsoft UxTheme
6.2.9200.16384
False
False
False
False
False
System.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\System\1b46657236c1f942f9dbaf6aac73bb49\System.ni.dll
System.dll
System.dll
2.0.50727.6401 (Win8RTMGDR.050727-6400)
.NET Framework
2.0.50727.6401
False
False
False
False
False
HTMLEditorControl.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\HTMLEditorControl\e7828c6a6b2d085f4c6d5130cc0ebb76\HTMLEditorControl.ni.dll
HTMLEditorControl.dll
5.0.17399.0
HtmlEditorControl
5.0.17399.0
False
False
False
False
False
Taalonafhankelijk
MailClient.Mail.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\MailClient.Mail\c97b547c318ecae6432f8b71c8bf4462\MailClient.Mail.ni.dll
MailClient.Mail.dll
MailClient.Mail.dll
5.0.17399.0
5.0.17399.0
False
False
False
False
False
Taalonafhankelijk
MailClient.Collections.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\MailClient.Collecti#\ad7953b34fc339e447aad84556ce65b1\MailClient.Collections.ni.dll
MailClient.Collections.dll
5.0.17399.0
5.0.17399.0
False
False
False
False
False
Taalonafhankelijk
MailClient.ni.exe
C:\Windows\assembly\NativeImages_v2.0.50727_32\MailClient\89eaa7a41eda73666baf8c5040efbfdb\MailClient.ni.exe
MailClient.exe
MailClient.exe
5.0.17399.0
eM Client
eM Client
5.0.17399.0
False
False
False
False
False
Taalonafhankelijk
Esent.Interop.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\Esent.Interop\3c2bdcb998fc83111d8010ff29004b7d\Esent.Interop.ni.dll
Esent.Interop.dll
Esent.Interop.dll
1.7.0.0
EsentInterop
EsentInterop
1.7.0.0
False
False
False
False
False
Taalonafhankelijk
Google.Apis.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\Google.Apis\d2cba82e3fb7575843de04369f4ad726\Google.Apis.ni.dll
Google.Apis.dll
Google.Apis.dll
1.2.4758.30152
GoogleApis
1.2.4758.30152
False
False
False
False
False
Taalonafhankelijk
Newtonsoft.Json.Net20.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\Newtonsoft.Json.Net#\2b6831380187685cfd63cce813555018\Newtonsoft.Json.Net20.ni.dll
Newtonsoft.Json.Net20.dll
4.0.2.13905
Newtonsoft Json.NET .NET 2.0
Newtonsoft Json.NET
4.0.2.13905
False
False
False
False
False
Taalonafhankelijk
jabber-net.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\jabber-net\ad8862ab011191631b3c088bbacffe04\jabber-net.ni.dll
jabber-net.dll
jabber-net.dll
5.0.2.0
Jabber-Net library
jabber-net
5.0.2.0
False
False
False
False
False
Taalonafhankelijk
MailClient.Interop.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\MailClient.Interop\510e1e936c0e8728c9631e5f23226223\MailClient.Interop.ni.dll
MailClient.Interop.dll
5.0.17399.0
5.0.17399.0
False
False
False
False
False
Taalonafhankelijk
WindowsAPICodePack.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\WindowsAPICodePack\095ec5e4ef3386a5020573b66d383861\WindowsAPICodePack.ni.dll
WindowsAPICodePack.dll
1.0.1.0
WindowsAPICodePack
WindowsAPICodePack
1.0.1.0
False
False
False
False
False
Taalonafhankelijk
FacebookAPI.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\FacebookAPI\d4622ec9b7fd7b201491bf83f91ccd3c\FacebookAPI.ni.dll
FacebookAPI.dll
FacebookAPI.dll
1.0.0.0
FacebookAPI
FacebookAPI
1.0.0.0
False
False
False
False
False
Taalonafhankelijk
NSkype.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\NSkype\9cf78deaf462796a873d16455a28eff0\NSkype.ni.dll
NSkype.dll
NSkype.dll
1.1.0.0
NSkype
NSkype
1.1.0.0
False
False
False
False
False
Taalonafhankelijk
MailClient.ExceptionUtils.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\MailClient.Exceptio#\7d21d6b5097f80ba1c51a2dfd4e7c9f9\MailClient.ExceptionUtils.ni.dll
MailClient.ExceptionUtils.dll
1.0.0.0
1.0.0.0
False
False
False
False
False
Taalonafhankelijk
System.Drawing.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\System.Drawing\7e4447d26cd9083018bd28ddd60a0248\System.Drawing.ni.dll
System.Drawing.dll
System.Drawing.dll
.NET Framework
2.0.50727.6401
False
False
False
False
False
System.Windows.Forms.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\System.Windows.Forms\6b49661877ca78101ebc697b9a6a95fd\System.Windows.Forms.ni.dll
System.Windows.Forms.dll
2.0.50727.6402 (Win8RTMGDR.050727-6400)
.NET Framework
2.0.50727.6402
False
False
False
False
False
System.Deployment.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\System.Deployment\c0f9f0bbaf724fe520eab2c616cf6444\System.Deployment.ni.dll
System.Deployment.dll
2.0.50727.6387
False
False
False
False
False
System.Xml.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\System.Xml\fc5d4ada42ed8e9a30b64912f5dc9767\System.Xml.ni.dll
System.Xml.dll
System.Xml.dll
2.0.50727.6411 (Win8RTMGDR.050727-6400)
.NET Framework
2.0.50727.6411
False
False
False
False
False
gdiplus.dll
C:\Windows\WinSxS\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.9200.16518_none_ba1cf6b7e09f1918\gdiplus.dll
gdiplus
gdiplus
6.2.9200.16518 (win8_gdr.130201-1704)
Microsoft GDI+
6.2.9200.16518
False
False
False
False
False
System.Configuration.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\System.Configuration\67ca465023d310bef5d3285a39444f14\System.Configuration.ni.dll
System.Configuration.dll
2.0.50727.6411
False
False
False
False
False
System.Deployment.resources.dll
C:\Windows\assembly\GAC_MSIL\System.Deployment.resources\2.0.0.0_nl_b03f5f7f11d50a3a\System.Deployment.resources.dll
2.0.50727.6387
False
False
False
False
False
dwmapi.dll
C:\Windows\SYSTEM32\dwmapi.dll
dwmapi.dll
dwmapi.dll.mui
API voor Beheer van bureaubladvensters van Microsoft
6.2.9200.16384
False
False
False
False
False
LinqBridge.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\LinqBridge\bf3e596727f8b0d9ba208e5aad5094a9\LinqBridge.ni.dll
LinqBridge.dll
LinqBridge.dll
1.3.13216.2214
LINQBridge
LINQBridge
1.3.13216.2214
False
False
False
False
False
Taalonafhankelijk
shfolder.dll
C:\Windows\SYSTEM32\shfolder.dll
shfolder
shfolder.dll
Shell Folder Service
6.2.9200.16384
False
False
False
False
False
System.Data.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\System.Data\25006a263912bf62c8bb0eb4e0b589ea\System.Data.ni.dll
system.data.dll
system.data.dll
.NET Framework
2.0.50727.6387
False
False
False
False
False
System.Data.dll
C:\Windows\assembly\GAC_32\System.Data\2.0.0.0__b77a5c561934e089\System.Data.dll
system.data.dll
system.data.dll
.NET Framework
2.0.50727.6387
False
False
False
False
False
WS2_32.dll
C:\Windows\SYSTEM32\WS2_32.dll
ws2_32.dll
ws2_32.dll.mui
Windows Socket 2.0 32-bits DLL-bestand
6.2.9200.16384
False
False
False
False
False
System.Runtime.Remoting.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\System.Runtime.Remo#\32e2f21d9b8c5614c650bb881d06e415\System.Runtime.Remoting.ni.dll
System.Runtime.Remoting.dll
Microsoft .NET Runtime Object Remoting
2.0.50727.6387
False
False
False
False
False
version.dll
C:\Windows\SYSTEM32\version.dll
version
VERSION.DLL
Version Checking and File Installation Libraries
6.2.9200.16384
False
False
False
False
False
System.Runtime.Remoting.resources.dll
C:\Windows\assembly\GAC_MSIL\System.Runtime.Remoting.resources\2.0.0.0_nl_b77a5c561934e089\System.Runtime.Remoting.resources.dll
2.0.50727.6387
False
False
False
False
False
diasymreader.dll
C:\Windows\Microsoft.NET\Framework\v2.0.50727\diasymreader.dll
diasymreader.dll
diasymreader.dll
8.0.50727.6387 (Win8RTM.050727-6300)
Dia based SymReader
8.0.50727.6387
False
False
True
True
False
mscorlib.resources.dll
C:\Windows\assembly\GAC_MSIL\mscorlib.resources\2.0.0.0_nl_b77a5c561934e089\mscorlib.resources.dll
2.0.50727.6400 (Win8RTMGDR.050727-6400)
Microsoft Common Language Runtime-klassenbibliotheek
2.0.50727.6400
False
False
False
False
False
PROPSYS.dll
C:\Windows\SYSTEM32\PROPSYS.dll
propsys.dll
propsys.dll.mui
7.00.9200.16384 (win8_rtm.120725-1247)
Microsoft Eigenschappensysteem
Windows® Search
7.00.9200.16384
False
False
False
False
False
OLEAUT32.dll
C:\Windows\SYSTEM32\OLEAUT32.dll
OLEAUT32.DLL
6.2.9200.16384
6.2.9200.16384
False
False
False
False
False
clbcatq.dll
C:\Windows\SYSTEM32\clbcatq.dll
CLBCATQ.DLL
CLBCATQ.DLL
2001.12.10130.16384 (win8_rtm.120725-1247)
COM+ Configuration Catalog
6.2.9200.16384
False
False
False
False
False
urlmon.dll
C:\Windows\SYSTEM32\urlmon.dll
UrlMon.dll
UrlMon.dll.mui
10.00.9200.16384 (win8_rtm.120725-1247)
OLE32-extensies voor Win32
Windows® Internet Explorer
10.00.9200.16384
False
False
False
False
False
iertutil.dll
C:\Windows\SYSTEM32\iertutil.dll
IeRtUtil.dll
IeRtUtil.dll.mui
Runtime-hulpprogramma voor Internet Explorer
10.00.9200.16384
False
False
False
False
False
WININET.dll
C:\Windows\SYSTEM32\WININET.dll
wininet.dll
wininet.dll.mui
Internetuitbreidingen voor Win32
10.00.9200.16384
False
False
False
False
False
Secur32.dll
C:\Windows\SYSTEM32\Secur32.dll
secur32.dll
secur32.dll
6.2.9200.16384
False
False
False
False
False
SETUPAPI.dll
C:\Windows\SYSTEM32\SETUPAPI.dll
SETUPAPI.DLL
SETUPAPI.DLL.MUI
Windows Setup API
6.2.9200.16384
False
False
False
False
False
CFGMGR32.dll
C:\Windows\SYSTEM32\CFGMGR32.dll
cfgmgr32.dll
CFGMGR32.DLL
Configuration Manager DLL
6.2.9200.16384
False
False
False
False
False
DEVOBJ.dll
C:\Windows\SYSTEM32\DEVOBJ.dll
devinfoset.dll
devinfoset.DLL
Device Information Set DLL
6.2.9200.16384
False
False
False
False
False
System.Data.SQLite.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\System.Data.SQLite\9ec04679c6e093f1186b8a653a2cbf0c\System.Data.SQLite.ni.dll
System.Data.SQLite.dll
1.0.67.3
System.Data.SQLite
System.Data.SQLite
1.0.67.3
False
False
False
False
False
Taalonafhankelijk
sqlite3.dll
C:\Program Files (x86)\SoftMaker Office Professional 2012\eM Client\SQLite\x86\sqlite3.dll
False
False
False
False
False
Microsoft.Search.Interop.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\Microsoft.Search.In#\729c58d73fa8cbc05592d253be3106e2\Microsoft.Search.Interop.ni.dll
Microsoft.Search.Interop.dll
1.0.0.0
Assembly imported from type library ‘SearchAPILib’.
1.0.0.0
False
False
False
False
False
Invariante taal (Invariant(e) land/regio)
System.Transactions.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\System.Transactions\cf49a998b717bce1bce9a417376fd6ab\System.Transactions.ni.dll
system.transactions.dll
.NET Framework
2.0.50727.6387
False
False
False
False
False
System.Transactions.dll
C:\Windows\assembly\GAC_32\System.Transactions\2.0.0.0__b77a5c561934e089\System.Transactions.dll
.NET Framework
2.0.50727.6387
False
False
False
False
False
mscorjit.dll
C:\Windows\Microsoft.NET\Framework\v2.0.50727\mscorjit.dll
mscorjit.dll
mscorjit.dll
Microsoft .NET Runtime Just-In-Time Compiler
2.0.50727.6401
False
False
False
False
False
System.EnterpriseServices.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\System.EnterpriseSe#\8fe60cfe4f5cb2cb30de3b640e9f94fb\System.EnterpriseServices.ni.dll
System.EnterpriseServices.dll
Microsoft .NET Services Support Infrastructure
2.0.50727.6387
False
False
False
False
False
MailClient.Sasl.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\MailClient.Sasl\8c1ec99b6b3bc307e3306ebc0993a3ad\MailClient.Sasl.ni.dll
MailClient.Sasl.dll
MailClient.Sasl.dll
5.0.17399.0
5.0.17399.0
False
False
False
False
False
Taalonafhankelijk
DWrite.dll
C:\Windows\SYSTEM32\DWrite.dll
DWrite
DWrite
Microsoft DirectX-typografieservices
6.2.9200.16384
False
False
False
False
False
WindowsCodecs.dll
C:\Windows\SYSTEM32\WindowsCodecs.dll
WindowsCodecs
WindowsCodecs
6.2.9200.16548 (win8_gdr.130301-1803)
Microsoft Windows Codecs Library
6.2.9200.16548
False
False
False
False
False
comctl32.dll
C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.9200.16579_none_8937eec6860750f5\comctl32.dll
comctl32
comctl32.DLL.MUI
6.10 (win8_rtm.120725-1247)
Bibliotheek met elementen voor gebruikerservaring
6.2.9200.16384
False
False
False
False
False
mswsock.dll
C:\Windows\system32\mswsock.dll
mswsock.dll
mswsock.dll.mui
Microsoft Windows Sockets 2.0 Service-aanbieder
6.2.9200.16384
False
False
False
False
False
napinsp.dll
C:\Windows\system32\napinsp.dll
napinsp.dll
napinsp.dll.mui
Shim-provider van e-mailnamen
6.2.9200.16384
False
False
False
False
False
pnrpnsp.dll
C:\Windows\system32\pnrpnsp.dll
pnrpnsp.dll
pnrpnsp.dll.mui
PNRP-naamruimteprovider
6.2.9200.16384
False
False
False
False
False
NLAapi.dll
C:\Windows\system32\NLAapi.dll
nlaapi.dll
nlaapi.dll
Network Location Awareness 2
6.2.9200.16518
False
False
False
False
False
DNSAPI.dll
C:\Windows\SYSTEM32\DNSAPI.dll
dnsapi
dnsapi
API DLL van DNS Client
6.2.9200.16384
False
False
False
False
False
winrnr.dll
C:\Windows\System32\winrnr.dll
winrnr
winrnr
LDAP RnR Provider DLL
6.2.9200.16384
False
False
False
False
False
ieframe.dll
C:\Windows\SYSTEM32\ieframe.dll
IEFRAME.DLL
IEFRAME.DLL.MUI
Internetbrowser
10.00.9200.16384
False
False
False
False
False
sxs.dll
C:\Windows\SYSTEM32\sxs.dll
SXS.DLL
SXS.DLL.MUI
Fusion 2.5
6.2.9200.16384
False
False
False
False
False
System.Windows.Forms.resources.dll
C:\Windows\assembly\GAC_MSIL\System.Windows.Forms.resources\2.0.0.0_nl_b77a5c561934e089\System.Windows.Forms.resources.dll
.NET Framework
2.0.50727.6400
False
False
False
False
False
RSS.NET.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\RSS.NET\2ba9a5a16a927f4741addab7738293e8\RSS.NET.ni.dll
RSS.NET.dll
RSS.NET.dll
0.87.0.0
RSS.NET
RSS.NET
0.87.0.0
False
False
False
False
False
Taalonafhankelijk
rasapi32.dll
C:\Windows\SYSTEM32\rasapi32.dll
rasapi32.dll
rasapi32.dll.mui
RAS-API
6.2.9200.16384
False
False
False
False
False
rasman.dll
C:\Windows\SYSTEM32\rasman.dll
Rasman.dll
Rasman.dll
Remote Access Connection Manager
6.2.9200.16384
False
False
False
False
False
rtutils.dll
C:\Windows\SYSTEM32\rtutils.dll
RTUTILS.DLL
RTUTILS.DLL
Routing Utilities
6.2.9200.16384
False
False
False
False
False
winhttp.dll
C:\Windows\SYSTEM32\winhttp.dll
winhttp.dll
winhttp.dll.mui
Windows HTTP-services
6.2.9200.16384
False
False
False
False
False
dhcpcsvc6.DLL
C:\Windows\SYSTEM32\dhcpcsvc6.DLL
dhcpcsvc6.dll
dhcpcsvc6.dll.mui
6.2.9200.16433 (win8_gdr.121010-1704)
DHCPv6-client
6.2.9200.16433
False
False
False
False
False
dhcpcsvc.DLL
C:\Windows\SYSTEM32\dhcpcsvc.DLL
dhcpcsvc.dll
dhcpcsvc.dll.mui
DHCP Client-service
6.2.9200.16433
False
False
False
False
False
rasadhlp.dll
C:\Windows\System32\rasadhlp.dll
rasadhlp.dll
rasadhlp.dll
Remote Access AutoDial Helper
6.2.9200.16384
False
False
False
False
False
fwpuclnt.dll
C:\Windows\System32\fwpuclnt.dll
fwpuclnt.dll
fwpuclnt.dll.mui
API voor FWP/IPsec in gebruikersmodus
6.2.9200.16384
False
False
False
False
False
System.Drawing.resources.dll
C:\Windows\assembly\GAC_MSIL\System.Drawing.resources\2.0.0.0_nl_b03f5f7f11d50a3a\System.Drawing.resources.dll
.NET Framework
2.0.50727.6400
False
False
False
False
False
apphelp.dll
C:\Windows\SYSTEM32\apphelp.dll
Apphelp
Apphelp
Toepassingscompatibiliteit van de client
6.2.9200.16384
False
False
False
False
False
mshtml.dll
C:\Windows\SYSTEM32\mshtml.dll
MSHTML
MSHTML.DLL.MUI
Microsoft ® HTML-viewer
10.00.9200.16384
False
False
False
False
False
Microsoft.VisualBasic.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\Microsoft.VisualBas#\dcadc7de71d458e1bb76af226ac7ea5e\Microsoft.VisualBasic.ni.dll
Microsoft.VisualBasic.DLL
Visual Basic Runtime Library
8.0.50727.6387
False
False
True
True
False
SgmlReader.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\SgmlReader\2ba7b307b6754b9e5898f11e618828e2\SgmlReader.ni.dll
SgmlReader.dll
SgmlReader.dll
5.1.17399.0
SgmlReader
SgmlReader
5.1.17399.0
False
False
False
False
False
Taalonafhankelijk
ntmarta.dll
C:\Windows\SYSTEM32\ntmarta.dll
ntmarta.dll
ntmarta.dll.mui
Windows NT MARTA-provider
6.2.9200.16384
False
False
False
False
False
MailClient.Imap.Base.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\MailClient.Imap.Base\eedd013381b97f2e1b2616cbaab92de0\MailClient.Imap.Base.ni.dll
5.0.17399.0
5.0.17399.0
False
False
False
False
False
Taalonafhankelijk
LINKINFO.dll
C:\Windows\SYSTEM32\LINKINFO.dll
LINKINFO
LINKINFO.DLL
Windows Volume Tracking
6.2.9200.16384
False
False
False
False
False
Bcp47Langs.dll
C:\Windows\SYSTEM32\Bcp47Langs.dll
BCP47Lang.dll
BCP47Lang.dll
6.2.9200.16604 (win8_gdr.130503-1646)
BCP47 Language Classes
6.2.9200.16604
False
False
False
False
False
ntshrui.dll
C:\Windows\SYSTEM32\ntshrui.dll
ntshrui
ntshrui.dll.mui
Shelluitbreidingen voor delen
6.2.9200.16384
False
False
False
False
False
srvcli.dll
C:\Windows\SYSTEM32\srvcli.dll
SRVCLI.DLL
SRVCLI.DLL
Server Service Client DLL
6.2.9200.16384
False
False
False
False
False
cscapi.dll
C:\Windows\SYSTEM32\cscapi.dll
cscapi.dll
cscapi.dll
Offline Files Win32 API
6.2.9200.16384
False
False
False
False
False
msimtf.dll
C:\Windows\system32\msimtf.dll
MSIMTF.DLL
MSIMTF.DLL.MUI
DLL voor actieve IMM-server
6.2.9200.16384
False
False
False
False
False
msls31.dll
C:\Windows\SYSTEM32\msls31.dll
msls31
MSLS31.DLL
3.10.349.0
Microsoft Line Services library file
Microsoft® Line Services
3.10
False
False
True
True
False
d2d1.dll
C:\Windows\SYSTEM32\d2d1.dll
d2d1
d2d1
Microsoft D2D-bibliotheek
6.2.9200.16384
False
False
False
False
False
dxgi.dll
C:\Windows\SYSTEM32\dxgi.dll
dxgi.dll
dxgi.dll
DirectX Graphics Infrastructure
6.2.9200.16420
False
False
False
several times I’ve send this report to eM from within the error interface, never got an answer!
This is problem on Avast’s side, we have made workaround but Avast made some weird patch that started to cause these problems again.
Only solution here is to switch to antivirus that actually works (for me it caused problems not only with eM Client but for example with Firefox or battlefield 3)
I am now running on NOD 32 from ESET and it is okay
regards
Jan
Thanks John, I had enough and just switch to Bitdefender, now everything’s OK
I am glad that I was able to solve your issue.
regards
Jan
Do you think this issue could be solved without uninstalling Avast soon ?
Sorry, the problem does not lie on our side so we cannot provide any fix.
Thank you for the reply.
I understand that Avast is responsible of this situation but how do you explain that others email client don’t have the same problem ? And with the number of people using Avast, don’t you think that you could think to an evolution of Em Client to avoid these issues with Avast ?
Anyway, do you know if there is a known modification of the settings of Avast that allow to keep Avast with Em Client ?
If not, what do you recommend free antivirus ?
Thanks
to my knowledge the bug still is there, but I 've switched to Bitdefender so i can’t check.
You could disable mail scanning in Avast, bad attatchments will be blocked in case you might open them and when you click on links in spam mail that lead to infected site I would not rely on Avast anyway but use the free and excellent Trafficlight for surfing protection
http://www.bitdefender.com/solutions/…
AVG free might be an option:
http://www.av-test.org/en/tests/home-…
you can disable SSL protection in Avast - it should make the problem disappear.
I’ve contacted the technical support of Avast. They said they will check this problem.
I do not know if this will help but I think we should try.
