Is there a way to have spell check actively call out misspelled words before you send a message? I know that words get highlighted, but I’d like to run a full check at the point of pressing “send.”
Hi Hannah, unfortunately it is not possible to auto spell check your outgoing message, but by using the F7 key or by navigating to Tools > Check spelling, you should be able to open a spellcheck setting, allowing you to check the spelling of your composed message.
Paul
