Using Delete more effectively!
Hello. I'm writing to remind you good folks of a suggestion I made some time ago. I'm truly hoping this can be implemented. Can we get the delete key to work whether the focus is in the message body or in the message list? In the list, delete works fine, but when you're in the message body, you must use alt-d to delete a message. It would be wonderful, wonderful, wonderful, for delete to work in either situation. Thank you!
Hello, thank you for reporting, it is already fixed internally and will be available with one of the future updates.
Loading Profile...
Twitter,
Facebook, or email.
