Update 2.6 causes starting problem
after update to 2.6 emclient doesn't start. Cannot access settings.xml. after sending report, emclient tries to restart, but fails again. I solved problem by re-install with version 2.5. But after update to 2.6 same problem. How to solve this?
What problem exactly do you receive?
You can also try patched version>
www.emclient.com/dist/v2.6.7033/setup... -
I installed the patched version, but got same problem: no start up, only possibility to send error report. The only way to be able to use emclient again now, is reinstall version 2.5.
I copied the report, see below:
(it's dutch: my translation: acces to path C:\Documents and Settings\Anneke en Jan\Application Data\eM Client\settings.xml denied)
eM Client (2.6.7033.0)
Windows: Microsoft Windows NT 5.1.2600 Service Pack 3, Framework: 2.0.50727.3603
System.UnauthorizedAccessException: Toegang tot het pad C:\Documents and Settings\Anneke en Jan\Application Data\eM Client\settings.xml is geweigerd.
bij System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
bij System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy)
bij System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
bij System.Xml.XmlTextWriter..ctor(String filename, Encoding encoding)
bij System.Xml.XmlDocument.Save(String filename)
bij MailClient.XmlSettings.SetValue(String key, String value)
bij MailClient.Program.Main(String[] args)
eM Client
2.6.7033.0
2.0.50727.3603
mscorlib
mscorlib.dll
100676671
mscorlib
System.IO.__Error
WinIOError
mscorlib
System.Int32
errorCode
mscorlib
System.String
maybeFullPath
b1
75b5cf
mscorlib.dll
100677015
mscorlib
Init
mscorlib
System.String
path
mscorlib
System.IO.FileMode
mode
mscorlib
System.IO.FileAccess
access
mscorlib
System.Int32
rights
mscorlib
System.Boolean
useRights
mscorlib
System.IO.FileShare
share
mscorlib
System.Int32
bufferSize
mscorlib
System.IO.FileOptions
options
mscorlib
Microsoft.Win32.Win32Native+SECURITY_ATTRIBUTES
secAttrs
mscorlib
System.String
msgPath
mscorlib
System.Boolean
bFromProxy
3be
48a
mscorlib.dll
100677008
mscorlib
.ctor
mscorlib
System.String
path
mscorlib
System.IO.FileMode
mode
mscorlib
access
mscorlib
System.IO.FileShare
share
0
42
System.Xml.dll
100665302
System.Xml
.ctor
mscorlib
System.String
filename
mscorlib
System.Text.Encoding
encoding
0
25
System.Xml.dll
100666530
System.Xml
Save
mscorlib
System.String
filename
1d
4d
MailClient.exe
100682991
MailClient
SetValue
mscorlib
System.String
key
mscorlib
System.String
value
57
7d
MailClient.exe
100679900
MailClient
MailClient.Program
Main
mscorlib
System.String[]
args
1bc
2f6
MailClient.exe
C:\Program Files\eM Client\MailClient.exe
MailClient.exe
MailClient.exe
2.6.7033.0
eM Client
eM Client
2.6.7033.0
False
False
False
False
False
Taalonafhankelijk
ntdll.dll
C:\WINDOWS\system32\ntdll.dll
ntdll.dll
ntdll.dll
5.1.2600.5755 (xpsp_sp3_gdr.090206-1234)
DLL-bestand voor NT-laag
Besturingssysteem Microsoft® Windows®
5.1.2600.5755
False
False
False
False
False
Nederlands (Nederland)
mscoree.dll
C:\WINDOWS\system32\mscoree.dll
mscoree.dll
mscoree.dll
2.0.50727.3053 (netfxsp.050727-3000)
Microsoft .NET Runtime Execution Engine
Microsoft® .NET Framework
2.0.50727.3053
False
False
False
False
False
Engels (Verenigde Staten)
KERNEL32.dll
C:\WINDOWS\system32\KERNEL32.dll
kernel32
kernel32
5.1.2600.5781 (xpsp_sp3_gdr.090321-1317)
DLL-bestand voor Windows NT BASE API-client
5.1.2600.5781
False
False
False
False
False
ADVAPI32.dll
C:\WINDOWS\system32\ADVAPI32.dll
advapi32.dll
advapi32.dll
Geavanceerde Windows 32 basis-API
5.1.2600.5755
False
False
False
False
False
RPCRT4.dll
C:\WINDOWS\system32\RPCRT4.dll
rpcrt4.dll
rpcrt4.dll
5.1.2600.5795 (xpsp_sp3_gdr.090415-1241)
Remote Procedure Call Runtime
Microsoft® Windows® Operating System
5.1.2600.5795
False
False
False
False
False
Secur32.dll
C:\WINDOWS\system32\Secur32.dll
security.dll
security.dll
5.1.2600.5834 (xpsp_sp3_gdr.090624-1305)
Security Support Provider Interface
5.1.2600.5834
False
False
False
False
False
SHLWAPI.dll
C:\WINDOWS\system32\SHLWAPI.dll
SHLWAPI
SHLWAPI.DLL
6.00.2900.5912 (xpsp_sp3_gdr.091207-1454)
Shell lichtgewicht hulpprogrammabibliotheek
6.00.2900.5912
False
False
False
False
False
GDI32.dll
C:\WINDOWS\system32\GDI32.dll
gdi32
gdi32
5.1.2600.5698 (xpsp_sp3_gdr.081022-1932)
GDI Client DLL
5.1.2600.5698
False
False
False
False
False
USER32.dll
C:\WINDOWS\system32\USER32.dll
user32
user32
5.1.2600.5512 (xpsp.080413-2105)
DLL-bestand voor Windows XP USER API-client
5.1.2600.5512
False
False
False
False
False
msvcrt.dll
C:\WINDOWS\system32\msvcrt.dll
msvcrt.dll
msvcrt.dll
7.0.2600.5512 (xpsp.080413-2111)
Windows NT CRT DLL
7.0.2600.5512
False
False
False
False
False
IMM32.DLL
C:\WINDOWS\system32\IMM32.DLL
imm32
imm32
Windows XP IMM32 API Client DLL
5.1.2600.5512
False
False
False
False
False
LPK.DLL
C:\WINDOWS\system32\LPK.DLL
LanguagePack
LanguagePack
Language Pack
5.1.2600.5512
False
False
False
False
False
USP10.dll
C:\WINDOWS\system32\USP10.dll
Uniscribe
Uniscribe
1.0420.2600.5512 (xpsp.080413-2105)
Uniscribe Unicode script processor
Microsoft(R) Uniscribe Unicode script processor
1.0420.2600.5512
False
False
False
False
False
mscorwks.dll
c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorwks.dll
mscorwks.dll
mscorwks.dll
2.0.50727.3603 (GDR.050727-3600)
Microsoft .NET Runtime Common Language Runtime - WorkStation
2.0.50727.3603
False
False
False
False
False
MSVCR80.dll
C:\WINDOWS\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_e6967989\MSVCR80.dll
MSVCR80.DLL
MSVCR80.DLL
8.00.50727.4053
Microsoft® C Runtime Library
Microsoft® Visual Studio® 2005
8.00.50727.4053
False
False
False
False
False
shell32.dll
C:\WINDOWS\system32\shell32.dll
SHELL32
SHELL32.DLL
6.00.2900.5622 (xpsp_sp3_gdr.080617-1319)
Gemeenschappelijk DLL-bestand van Windows Shell
6.00.2900.5622
False
False
False
False
False
comctl32.dll
C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.5512_x-ww_35d4ce83\comctl32.dll
comctl32
comctl32.DLL
6.0 (xpsp.080413-2105)
User Experience Controls Library
6.00.2900.5512
False
False
False
False
False
comctl32.dll
C:\WINDOWS\system32\comctl32.dll
COMCTL32
COMCTL32.DLL
5.82 (xpsp.080413-2105)
Common Controls Library
6.00.2900.5512
False
False
False
False
False
mscorlib.ni.dll
C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\mscorlib\7124a40b9998f7b63c86bd1a2125ce26\mscorlib.ni.dll
mscorlib.dll
mscorlib.dll
Microsoft Common Language Runtime Class Library
2.0.50727.3603
False
False
False
False
False
ole32.dll
C:\WINDOWS\system32\ole32.dll
OLE32.DLL
OLE32.DLL
5.1.2600.5512 (xpsp.080413-2108)
Microsoft OLE voor Windows
5.1.2600.5512
False
False
False
False
False
uxtheme.dll
C:\WINDOWS\system32\uxtheme.dll
UxTheme.dll
UxTheme.dll
6.00.2900.5512 (xpsp.080413-2105)
DLL-bestand Microsoft UxTheme
6.00.2900.5512
False
False
False
False
False
ASOEHOOK.DLL
C:\PROGRAM FILES\NORTON 360 PREMIER EDITION\ENGINE\4.0.0.127\ASOEHOOK.DLL
asOEHook.dll
asOEHook.dll
17.5.0.127
AntiSpam OE Hook
Symantec Shared Component
17.5
False
False
False
False
False
OLEAUT32.dll
C:\WINDOWS\system32\OLEAUT32.dll
OLEAUT32.DLL
5.1.2600.5512
5.1.2600.5512
False
False
False
False
False
MSVCR90.dll
C:\PROGRAM FILES\NORTON 360 PREMIER EDITION\ENGINE\4.0.0.127\Microsoft.VC90.CRT\MSVCR90.dll
MSVCR90.DLL
MSVCR90.DLL
9.00.30729.4148
Microsoft® Visual Studio® 2008
9.00.30729.4148
False
False
False
False
False
MSVCP90.dll
C:\PROGRAM FILES\NORTON 360 PREMIER EDITION\ENGINE\4.0.0.127\Microsoft.VC90.CRT\MSVCP90.dll
MSVCP90.DLL
MSVCP90.DLL
9.00.30729.4148
Microsoft® C++ Runtime Library
9.00.30729.4148
False
False
False
False
False
saHook.dll
C:\Program Files\McAfee\SiteAdvisor\saHook.dll
Email IM Annotation Hook
saHook.dll
2,8,0,306
SiteAdvisor
McAfee SiteAdvisor
2,8,0,0
False
False
False
False
False
MSCTF.dll
C:\WINDOWS\system32\MSCTF.dll
MSCTF
MSCTF.DLL
DLL-bestand voor MSCTF-server
5.1.2600.5512
False
False
False
False
False
mscorjit.dll
c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorjit.dll
mscorjit.dll
mscorjit.dll
2.0.50727.3082 (QFE.050727-3000)
Microsoft .NET Runtime Just-In-Time Compiler
2.0.50727.3082
False
False
False
False
False
System.ni.dll
C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System\3de5bd01124463d7862bd173af90bc83\System.ni.dll
System.dll
System.dll
.NET Framework
2.0.50727.3053
False
False
False
False
False
System.Drawing.ni.dll
C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.Drawing\abb2ac7e08bee026f857d8fa36f9fe6f\System.Drawing.ni.dll
System.Drawing.dll
System.Drawing.dll
.NET Framework
2.0.50727.3053
False
False
False
False
False
System.Windows.Forms.ni.dll
C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.Windows.Forms\d2ea8d76f015817db1607075812b555f\System.Windows.Forms.ni.dll
System.Windows.Forms.dll
.NET Framework
2.0.50727.3053
False
False
False
False
False
System.Deployment.ni.dll
C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.Deployment\c94a427baa7683f4221b91f90c18461b\System.Deployment.ni.dll
System.Deployment.dll
2.0.50727.3053
False
False
False
False
False
System.Xml.ni.dll
C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.Xml\5913d3f81e77194ec833991b1047a532\System.Xml.ni.dll
System.Xml.dll
System.Xml.dll
.NET Framework
2.0.50727.3082
False
False
False
False
False
System.Deployment.resources.dll
C:\WINDOWS\assembly\GAC_MSIL\System.Deployment.resources\2.0.0.0_nl_b03f5f7f11d50a3a\System.Deployment.resources.dll
2.0.50727.42 (RTM.050727-4200)
2.0.50727.42
False
False
False
False
False
msctfime.ime
C:\WINDOWS\system32\msctfime.ime
MSCTFIME
MSCTFIME.IME
5.1.2600.5768 (xpsp_sp3_gdr.090226-1442)
Microsoft Text Frame Work Service IME
5.1.2600.5768
False
False
False
False
False
Taalonafhankelijk
shfolder.dll
C:\WINDOWS\system32\shfolder.dll
shfolder
shfolder.dll
Shell Folder Service
6.00.2900.5512
False
False
False
False
False
System.Data.ni.dll
C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.Data\694c07365e0fd6bba0bc304d4d2404a7\System.Data.ni.dll
system.data.dll
system.data.dll
.NET Framework
2.0.50727.3053
False
False
False
False
False
System.Data.dll
C:\WINDOWS\assembly\GAC_32\System.Data\2.0.0.0__b77a5c561934e089\System.Data.dll
system.data.dll
system.data.dll
.NET Framework
2.0.50727.3053
False
False
False
False
False
WS2_32.dll
C:\WINDOWS\system32\WS2_32.dll
ws2_32.dll
ws2_32.dll
5.1.2600.5512 (xpsp.080413-0852)
Windows Socket 2.0 32-Bit DLL
5.1.2600.5512
False
False
False
False
False
WS2HELP.dll
C:\WINDOWS\system32\WS2HELP.dll
ws2help.dll
ws2help.dll
Windows Socket 2.0-helper voor Windows NT
5.1.2600.5512
False
False
False
False
False
CRYPT32.dll
C:\WINDOWS\system32\CRYPT32.dll
CRYPT32.DLL
CRYPT32.DLL
5.131.2600.5512 (xpsp.080413-2113)
Crypto-API32
5.131.2600.5512
False
False
False
False
False
MSASN1.dll
C:\WINDOWS\system32\MSASN1.dll
msasn1.dll
msasn1.dll
5.1.2600.5875 (xpsp_sp3_gdr.090904-1413)
ASN.1 Runtime APIs
5.1.2600.5875
False
False
False
False
False
mscorlib.resources.dll
C:\WINDOWS\assembly\GAC_MSIL\mscorlib.resources\2.0.0.0_nl_b77a5c561934e089\mscorlib.resources.dll
Microsoft Common Language Runtime-klassenbibliotheek
2.0.50727.42
False
False
False
False
False
rsaenh.dll
C:\WINDOWS\system32\rsaenh.dll
rsaenh.dll
rsaenh.dll
5.1.2600.5507 (xpsp.080318-1711)
Microsoft Enhanced Cryptographic Provider
5.1.2600.5507
False
False
False
False
False
version.dll
C:\WINDOWS\system32\version.dll
version
VERSION.DLL
Version Checking and File Installation Libraries
5.1.2600.5512
False
False
False
False
False
diasymreader.dll
c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\diasymreader.dll
diasymreader.dll
diasymreader.dll
8.0.50727.3053 (netfxsp.050727-3000)
Dia based SymReader
8.0.50727.3053
False
False
True
True
False
psapi.dll
C:\WINDOWS\system32\psapi.dll
PSAPI
PSAPI
Process Status Helper
5.1.2600.5512
False
False
False
False
False
Engels (Verenigde Staten) -
additional information:
update version 2.6, date 26/03 still causes the same problem.
I red: "company has a solution in progress"
that good news!
Who can inform me about the progress?
thanks
Jan -
They've posted a new build about an hour ago - 2.6.7065 - which seems to fix a lot of bugs.
Link: http://www.emclient.com/dist/v2.6.706... -
Hi, the error message says that eM Client does not have access rights to file C:\Documents and Settings\Anneke en Jan\Application Data\eM Client\settings.xml, which is strange, because it is a application folder for eM Client. Try to delete (backup first) this file (in fact eM Client will run just fine without it) or take a look on access rights for this file. Do you use some antivirus or harddisk data crypring utility or something like that?
Thanks for suggestions.
I did following:
1. de-install emclient 2.5
2. remove “settings.xml”
3. download and install emclient 2.6.6075
Results:
emclient started up, and I saw 2 seconds the new layout, but than emclient crashed
(I sent error-report to emclient-support, but I forgot to look into the report).
Second start up began with database check.
And..... stopped and reported error in mail_index.dat
Third start up began with database check again and reported again error in mail_index.dat
Then I de-installed 2.6 and re-installed 2.5 (the reliable version)
Emclient 2.5 started up and check the databased AND said: OK
Emclient 2.5 finished starting up, BUT..... a second later.....did not accepted newer version of database. L
Then I de-installed 2.5 and re-installed 2.6.6075
But check database reported again error in mail_index.dat
With Norton Undelete I checked deleted files and found many mail_index.dat-fix.
I undeleted an older version of this file, but no better result.
So, total result:
1. 2.6.6075 crashed
2. database (mail index) corrupt
3. old reliable version 2.5 cannot use newer version of database
Now, I cannot use any emclient version. My problem is bigger, now!
(I can use my back-up data files – lucky my, but unfortunately few days old -, but that will not be the best solution for me, because emclient will crash again and I would like to get back the most recent database)
What solution does emclient recommend?
Can I change back the version of database to 2.5?
Looking forward to find a solution, because I like to continue using emclient. But version 2.6 seems a very unstable version.
Beste regards
Jan van der Heide -
A few suggestions:
1. Check the permissions on the folder C:\Documents and Settings\Anneke en Jan\Application Data\eM Client, and try re-applying them - see http://support.microsoft.com/kb/308421 for a guide.
2. Try the release build 2.6.7067 -
I forgot to tell, that I already changed the directory from "hidden" into "not hidden". Maybe that's one of the reasons that emclient started up. (But unfortunately crashed later)
How can I get the newest release?
And how to solve my database problem? -
After I had contacted "support@emclient.com" they helped me and found the solution. Thanks!
Loading Profile...
Twitter,
Facebook, or email.
