OK so like a prat i reformated my laptop in a hurry and when i saved my eM client settings i just copied the Em folder frol Appdata and now it wont load my old settings and mail.
This was how i used to do it in Thunderbird with the profile folder and i thought it was the same but alas it is not..
Any ideas how i can add the old folders from my previous installation... I have tried pasting them in the folder but this does not work.
Presumably, you copied this directory:
C:\Users\****\AppData\Roaming\eM Client\
Reading what it says in tools, settings, storage - implies you can import this way. Have you installed exactly back to the same place and overwritten your eM Client folder with the old one - or are you pasting inside it? Never tried it myself, so don't know how this works.
There is some blurb about the settings.xml file needing to be retained. -
There are three things you can do to remedy this situation:
1) Update to the latest version available at http://www.emclient.com/dist/latest/s... and then go to Start -> Run and type the following:
"C:\Program Files\eM Client\DbRepair.exe" /checkall
or alternatively, if you use 64-bit system:
"C:\Program Files (x86)\eM Client\DbRepair.exe" /checkall
2) Download a tool from http://www.emclient.com/tools/DbRepai... and run it.
3) Delete the database files located in C:\Users\[your user name]\AppData\Roaming\eM Client (on Windows Vista/Windows 7) or C:\Documents and Settings\[your user name]\Application Data\eM Client (on Windows XP). This will remove all settings though. -
HI Gabriel
Thanks for your reply but i have now re installed from scratch again.
I have one problem though and that is the migration of my emails.
I have some of them saved on the mail server but not all.
I have the following folders saved. Do any of these contain my emails and if so can i import them somehow?
The files are listed in the attached screen shot.
it's hard to extract your old mails (or repair database) if you don't have files mail_fti.dat and mail_index.dat as I can see from your screenshot list. Try to find them. -
If our repair tools don't work with these files you found, please send me the email to staron@emclient.com and I will instruct you further.
Having had a second look....
These files above are in my bin and i think they are just from previous failed attempts. but i will keep looking. -
Looks like i have lost some of my emails luckily most of them were on the server but lesson learnt i guess check and double check before re formatting.
Thanks to everyone who has offered help and support.
Mark -
Loading Profile...
Twitter,
Facebook, or email.
did it display some error message or it just loaded as with blank settings?
Infact if i remember correctly when i opened Emclient it displayed the corrupted database box and searched for 2 different things... the second one was the problem but i forget what it was...
Windows: Microsoft Windows NT 6.0.6002 Service Pack 2, Framework: 2.0.50727.4211
System.Data.SQLite.SQLiteException: The database disk image is malformed
malformed database schema (IMMessagesIndex3_contentIndex) - no such table: im_data.IMMessagesIndex3_content
at System.Data.SQLite.SQLite3.Reset(SQLiteStatement stmt)
at System.Data.SQLite.SQLite3.Step(SQLiteStatement stmt)
at System.Data.SQLite.SQLiteDataReader.NextResult()
at System.Data.SQLite.SQLiteDataReader..ctor(SQLiteCommand cmd, CommandBehavior behave)
at System.Data.SQLite.SQLiteCommand.ExecuteReader(CommandBehavior behavior)
at System.Data.SQLite.SQLiteCommand.ExecuteNonQuery()
at MailClient.Storage.Data.SQLite.DbRepository`1..ctor(Compactor compactor, String indexTable, String[] readWriteDatabaseNames, String[] readOnlyDatabaseNames)
at MailClient.Storage.Data.SQLite.DbIMMessageRepository..ctor(Compactor compactor)
at MailClient.Storage.Data.RepositoryFactory.get_IMMessageRepository()
at MailClient.IM.IMManager..ctor()
at MailClient.IM.IMManager.Initialize()
at MailClient.Program.Main(String[] args)
eM Client
3.0.9716.0
2.0.50727.4211
System.Data.SQLite
System.Data.SQLite.dll
100663569
System.Data.SQLite
Reset
System.Data.SQLite
System.Data.SQLite.SQLiteStatement
stmt
0
148ed
100663568
System.Data.SQLite
Step
System.Data.SQLite
stmt
3d
d0
100663834
System.Data.SQLite
NextResult
f8
d1
100663799
System.Data.SQLite
.ctor
System.Data.SQLite
cmd
System.Data
System.Data.CommandBehavior
behave
4e
60
100663435
System.Data.SQLite
ExecuteReader
System.Data
behavior
6
26
100663438
System.Data.SQLite
ExecuteNonQuery
0
27
MailClient.exe
100665162
MailClient
.ctor
MailClient
MailClient.Storage.Data.Compactor
compactor
mscorlib
System.String
indexTable
mscorlib
System.String[]
mscorlib
System.String[]
ad
1bb
MailClient.exe
100672654
MailClient
.ctor
MailClient
compactor
0
4c
MailClient.exe
100684923
MailClient
15
72
MailClient.exe
100688228
MailClient
.ctor
12
51
MailClient.exe
100688229
MailClient
Initialize
15
8a
MailClient.exe
100680874
MailClient
MailClient.Program
Main
mscorlib
System.String[]
args
97e
1379
-2147467259
MailClient.exe
C:\Program Files\eM Client\MailClient.exe
MailClient.exe
MailClient.exe
3.0.9716.0
eM Client
eM Client
3.0.9716.0
False
False
False
False
False
Language Neutral
ntdll.dll
C:\Windows\system32\ntdll.dll
ntdll.dll
ntdll.dll.mui
6.0.6001.18000 (longhorn_rtm.080118-1840)
NT Layer DLL
Microsoft® Windows® Operating System
6.0.6001.18000
False
False
False
False
False
English (United States)
mscoree.dll
C:\Windows\system32\mscoree.dll
mscoree.dll
mscoree.dll
4.0.31106.0 (Main.031106-0000)
Microsoft .NET Runtime Execution Engine
Microsoft® .NET Framework
4.0.31106.0
False
False
False
True
False
KERNEL32.dll
C:\Windows\system32\KERNEL32.dll
kernel32
kernel32
Windows NT BASE API Client DLL
6.0.6001.18000
False
False
False
False
False
ADVAPI32.dll
C:\Windows\system32\ADVAPI32.dll
advapi32.dll
advapi32.dll.mui
6.0.6002.18005 (lh_sp2rtm.090410-1830)
Advanced Windows 32 Base API
6.0.6002.18005
False
False
False
False
False
RPCRT4.dll
C:\Windows\system32\RPCRT4.dll
rpcrt4.dll
rpcrt4.dll.mui
Remote Procedure Call Runtime
6.0.6001.18000
False
False
False
False
False
mscoreei.dll
C:\Windows\Microsoft.NET\Framework\v4.0.30319\mscoreei.dll
mscoreei.dll
mscoreei.dll
4.0.30319.1 (RTMRel.030319-0100)
4.0.30319.1
False
False
False
True
False
SHLWAPI.dll
C:\Windows\system32\SHLWAPI.dll
SHLWAPI
SHLWAPI.DLL.MUI
6.0.6000.16386 (vista_rtm.061101-2205)
Shell Light-weight Utility Library
6.0.6000.16386
False
False
False
False
False
GDI32.dll
C:\Windows\system32\GDI32.dll
gdi32
gdi32
GDI Client DLL
6.0.6002.18005
False
False
False
False
False
USER32.dll
C:\Windows\system32\USER32.dll
user32
user32
Multi-User Windows USER API Client DLL
6.0.6001.18000
False
False
False
False
False
msvcrt.dll
C:\Windows\system32\msvcrt.dll
msvcrt.dll
msvcrt.dll
7.0.6002.18005 (lh_sp2rtm.090410-1830)
Windows NT CRT DLL
7.0.6002.18005
False
False
False
False
False
IMM32.DLL
C:\Windows\system32\IMM32.DLL
imm32
imm32
Multi-User Windows IMM32 API Client DLL
6.0.6002.18005
False
False
False
False
False
MSCTF.dll
C:\Windows\system32\MSCTF.dll
MSCTF
MSCTF.DLL.MUI
MSCTF Server DLL
6.0.6000.16386
False
False
False
False
False
LPK.DLL
C:\Windows\system32\LPK.DLL
LanguagePack
LanguagePack
6.0.6002.18051 (vistasp2_gdr.090615-0258)
Language Pack
6.0.6002.18051
False
False
False
False
False
USP10.dll
C:\Windows\system32\USP10.dll
Uniscribe
Uniscribe
1.0626.6002.18244 (vistasp2_gdr.100416-0345)
Uniscribe Unicode script processor
Microsoft(R) Uniscribe Unicode script processor
1.0626.6002.18244
False
False
False
False
False
comctl32.dll
C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.6002.18305_none_5cb72f2a088b0ed3\comctl32.dll
comctl32
comctl32.DLL.MUI
6.10 (longhorn_rtm.080118-1840)
User Experience Controls Library
6.0.6001.18000
False
False
False
False
False
mscorwks.dll
C:\Windows\Microsoft.NET\Framework\v2.0.50727\mscorwks.dll
mscorwks.dll
mscorwks.dll
2.0.50727.4211 (VistaSP2GDR.050727-4200)
Microsoft .NET Runtime Common Language Runtime - WorkStation
2.0.50727.4211
False
False
False
False
False
MSVCR80.dll
C:\Windows\WinSxS\x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4053_none_d08d7da0442a985d\MSVCR80.dll
MSVCR80.DLL
MSVCR80.DLL
8.00.50727.4053
Microsoft® C Runtime Library
Microsoft® Visual Studio® 2005
8.00.50727.4053
False
False
False
False
False
shell32.dll
C:\Windows\system32\shell32.dll
SHELL32
SHELL32.DLL.MUI
Windows Shell Common Dll
6.0.6001.18000
False
False
False
False
False
ole32.dll
C:\Windows\system32\ole32.dll
OLE32.DLL
OLE32.DLL.MUI
Microsoft OLE for Windows
6.0.6000.16386
False
False
False
False
False
mscorlib.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\mscorlib\b2a5854682691830b9f62ec351c8b54e\mscorlib.ni.dll
mscorlib.dll
mscorlib.dll
Microsoft Common Language Runtime Class Library
2.0.50727.4211
False
False
False
False
False
uxtheme.dll
C:\Windows\system32\uxtheme.dll
UxTheme.dll
UxTheme.dll.mui
Microsoft UxTheme Library
6.0.6000.16386
False
False
False
False
False
System.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\System\45f10e36f25d92dd808caab75e45b8ae\System.ni.dll
System.dll
System.dll
2.0.50727.4205 (VistaSP2GDR.050727-4200)
.NET Framework
2.0.50727.4205
False
False
False
False
False
rsaenh.dll
C:\Windows\system32\rsaenh.dll
rsaenh.dll
rsaenh.dll
Microsoft Enhanced Cryptographic Provider
6.0.6002.18005
False
False
False
False
False
HTMLEditorControl.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\HTMLEditorControl\4a2ef068c06533e71ea47f0d168670b5\HTMLEditorControl.ni.dll
HTMLEditorControl.dll
1.1.9714.0
HtmlEditorControl
1.1.9714.0
False
False
False
False
False
Language Neutral
MailClient.Collections.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\MailClient.Collecti#\c6ff85c64ff5cc6faa623f3613133475\MailClient.Collections.ni.dll
MailClient.Collections.dll
1.0.9645.0
1.0.9645.0
False
False
False
False
False
Language Neutral
MailClient.Mail.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\MailClient.Mail\889acf4565f128861b3d4c8ce0d10201\MailClient.Mail.ni.dll
MailClient.Mail.dll
MailClient.Mail.dll
3.0.9645.0
3.0.9645.0
False
False
False
False
False
Language Neutral
MailClient.ni.exe
C:\Windows\assembly\NativeImages_v2.0.50727_32\MailClient\15ab8f282dcba958a7094ca7d2002f3b\MailClient.ni.exe
MailClient.exe
MailClient.exe
3.0.9716.0
eM Client
eM Client
3.0.9716.0
False
False
False
False
False
Language Neutral
OutlookAccountInterfaces.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\OutlookAccountInter#\f17cc466f8a7b301d6933d85b44b2627\OutlookAccountInterfaces.ni.dll
OutlookAccountInterfaces.dll
1.0.0.1
1.0.0.1
False
False
False
False
False
Language Neutral
Interop.SKYPE4COMLib.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\Interop.SKYPE4COMLib\74e494657a78b7f1fd9e96600c3c8879\Interop.SKYPE4COMLib.ni.dll
Interop.SKYPE4COMLib.dll
1.0.0.0
Assembly imported from type library 'SKYPE4COMLib'.
1.0.0.0
False
False
False
False
False
Invariant Language (Invariant Country)
NHunspell.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\NHunspell\40958c5f93b01e24be96330d5504ff39\NHunspell.ni.dll
NHunspell.dll
NHunspell.dll
0.9.6.0
NHunspell
NHunspell
0.9.6.0
False
False
False
False
False
Language Neutral
Facebook.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\Facebook\22d2ce39031f65d019e94a245145157c\Facebook.ni.dll
Facebook.dll
Facebook.dll
1.7.0.0
Facebook
Facebook
1.7.0.0
False
False
False
False
False
Language Neutral
GoogleTranslateAPI.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\GoogleTranslateAPI\e32bb51937bcd99541aa6cda74f69452\GoogleTranslateAPI.ni.dll
GoogleTranslateAPI.dll
0.1.0.0
Google Translate API for .NET
GoogleTranslateAPI
0.1.0.0
False
False
False
False
False
Language Neutral
SgmlReader.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\SgmlReader\42910ed664b457fda3a448e545b6f425\SgmlReader.ni.dll
SgmlReader.dll
SgmlReader.dll
1.0.9645.0
SgmlReader
SgmlReader
1.0.9645.0
False
False
False
False
False
Language Neutral
RSS.NET.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\RSS.NET\94e5a274d4adac7a0a5c0725dc74b168\RSS.NET.ni.dll
RSS.NET.dll
RSS.NET.dll
0.86.2999.26295
RSS.NET
RSS.NET
0.86.2999.26295
False
False
False
False
False
Language Neutral
Microsoft.Experimental.IO.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\Microsoft.Experimen#\0afbcada516d814cdb977ac96724ceb7\Microsoft.Experimental.IO.ni.dll
Microsoft.Experimental.IO.dll
1.0.0.0
1.0.0.0
False
False
False
False
False
Language Neutral
PrintingInterop.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\PrintingInterop\72a54165aa5213cf0718bbe0e8428cb6\PrintingInterop.ni.dll
False
False
False
False
False
Interop.QuartzTypeLib.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\Interop.QuartzTypeL#\0a093a7776c12013164467889d987269\Interop.QuartzTypeLib.ni.dll
Interop.QuartzTypeLib.dll
1.0.0.0
Assembly imported from type library QuartzTypeLib
1.0.0.0
False
False
False
False
False
System.Drawing.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\System.Drawing\d5100c24f083084e1d2556839904e987\System.Drawing.ni.dll
System.Drawing.dll
System.Drawing.dll
2.0.50727.4016 (NetFxQFE.050727-4000)
.NET Framework
2.0.50727.4016
False
False
False
False
False
System.Windows.Forms.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\System.Windows.Forms\2bc8bc432d91919ea0bbb2b803a4b6af\System.Windows.Forms.ni.dll
System.Windows.Forms.dll
.NET Framework
2.0.50727.4016
False
False
False
False
False
System.Deployment.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\System.Deployment\af9926fcbda1e5916461b5198cf0d325\System.Deployment.ni.dll
System.Deployment.dll
2.0.50727.4016
False
False
False
False
False
System.Xml.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\System.Xml\653b1be0c33cfade02fb0a61f135e488\System.Xml.ni.dll
System.Xml.dll
System.Xml.dll
.NET Framework
2.0.50727.4016
False
False
False
False
False
shfolder.dll
C:\Windows\system32\shfolder.dll
shfolder
shfolder.dll
Shell Folder Service
6.0.6000.16386
False
False
False
False
False
System.Data.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\System.Data\e1053db6ce65cc97268fc79cc380f0c1\System.Data.ni.dll
system.data.dll
system.data.dll
.NET Framework
2.0.50727.4016
False
False
False
False
False
System.Data.dll
C:\Windows\assembly\GAC_32\System.Data\2.0.0.0__b77a5c561934e089\System.Data.dll
system.data.dll
system.data.dll
.NET Framework
2.0.50727.4016
False
False
False
False
False
WS2_32.dll
C:\Windows\system32\WS2_32.dll
ws2_32.dll
ws2_32.dll.mui
Windows Socket 2.0 32-Bit DLL
6.0.6000.16386
False
False
False
False
False
NSI.dll
C:\Windows\system32\NSI.dll
nsi.dll
nsi.dll
NSI User-mode interface DLL
6.0.6001.18000
False
False
False
False
False
CRYPT32.dll
C:\Windows\system32\CRYPT32.dll
CRYPT32.DLL
CRYPT32.DLL.MUI
Crypto API32
6.0.6000.16386
False
False
False
False
False
MSASN1.dll
C:\Windows\system32\MSASN1.dll
msasn1.dll
msasn1.dll
6.0.6002.18106 (vistasp2_gdr.090903-2340)
ASN.1 Runtime APIs
6.0.6002.18106
False
False
False
False
False
USERENV.dll
C:\Windows\system32\USERENV.dll
userenv
userenv.dll.mui
Userenv
6.0.6000.16386
False
False
False
False
False
Secur32.dll
C:\Windows\system32\Secur32.dll
security.dll
security.dll
Security Support Provider Interface
6.0.6002.18051
False
False
False
False
False
System.Data.SQLite.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\System.Data.SQLite\b4e6a9995ad11b9c76d7b1c3f113c3c3\System.Data.SQLite.ni.dll
1.0.64.0
System.Data.SQLite
System.Data.SQLite
1.0.64.0
False
False
False
False
False
Language Neutral
sqlite3.dll
C:\Program Files\eM Client\SQLite\x86\sqlite3.dll
False
False
False
False
False
System.Transactions.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\System.Transactions\2e1f77805242e6ba616571580f9aad81\System.Transactions.ni.dll
system.transactions.dll
.NET Framework
2.0.50727.4016
False
False
False
False
False
System.Transactions.dll
C:\Windows\assembly\GAC_32\System.Transactions\2.0.0.0__b77a5c561934e089\System.Transactions.dll
.NET Framework
2.0.50727.4016
False
False
False
False
False
System.Web.Services.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\System.Web.Services\1113c8ce01a5bc82bfde60e7bf4adcf1\System.Web.Services.ni.dll
System.Web.Services.dll
.NET Framework
2.0.50727.4016
False
False
False
False
False
Microsoft.Office.Interop.Outlook.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\Microsoft.Office.In#\90af398a2449fbd58cd797e3209e7537\Microsoft.Office.Interop.Outlook.ni.dll
Outlook Primary Interop Assembly
14.0.4536.1000
Microsoft Office 2010
14.0.4536.1000
False
False
True
False
True
Language Neutral
mscorsec.dll
C:\Windows\Microsoft.NET\Framework\v2.0.50727\mscorsec.dll
mscorsec.dll
mscorsec.dll
Microsoft .NET Security module
2.0.50727.4016
False
False
False
False
False
WINTRUST.dll
C:\Windows\system32\WINTRUST.dll
WINTRUST.DLL
WINTRUST.DLL
6.0.6002.18169 (vistasp2_gdr.091222-2238)
Microsoft Trust Verification APIs
6.0.6002.18169
False
False
False
False
False
imagehlp.dll
C:\Windows\system32\imagehlp.dll
IMAGEHLP.DLL
IMAGEHLP.DLL
Windows NT Image Helper
6.0.6001.18000
False
False
False
False
False
COMCTL32.dll
C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_5.82.6002.18305_none_88f3a38569c2c436\COMCTL32.dll
COMCTL32
COMCTL32.DLL.MUI
5.82 (longhorn_rtm.080118-1840)
Common Controls Library
6.0.6001.18000
False
False
False
False
False
psapi.dll
C:\Windows\system32\psapi.dll
PSAPI
PSAPI
Process Status Helper
6.0.6000.16386
False
False
False
False
False
ncrypt.dll
C:\Windows\system32\ncrypt.dll
ncrypt.dll
ncrypt.dll
Windows cryptographic library
6.0.6002.18005
False
False
False
False
False
BCRYPT.dll
C:\Windows\system32\BCRYPT.dll
bcrypt.dll
bcrypt.dll
Windows Cryptographic Primitives Library
6.0.6002.18005
False
False
False
False
False
NTMARTA.DLL
C:\Windows\system32\NTMARTA.DLL
ntmarta.dll
ntmarta.dll.mui
Windows NT MARTA provider
6.0.6000.16386
False
False
False
False
False
WLDAP32.dll
C:\Windows\system32\WLDAP32.dll
WLDAP32.DLL
WLDAP32.DLL.MUI
Win32 LDAP API DLL
6.0.6000.16386
False
False
False
False
False
SAMLIB.dll
C:\Windows\system32\SAMLIB.dll
SAMLib.DLL
SAMLib.DLL
SAM Library DLL
6.0.6002.18005
False
False
False
False
False
GPAPI.dll
C:\Windows\system32\GPAPI.dll
gpapi.dll
gpapi.dll.mui
Group Policy Client API
6.0.6000.16386
False
False
False
False
False
slc.dll
C:\Windows\system32\slc.dll
slcdll.dll
slcdll.dll.mui
Software Licensing Client Dll
6.0.6002.18005
False
False
False
False
False
cryptnet.dll
C:\Windows\system32\cryptnet.dll
CRYPTNET.DLL
CRYPTNET.DLL
Crypto Network Related API
6.0.6001.18000
False
False
False
False
False
SensApi.dll
C:\Windows\system32\SensApi.dll
SensApi.dll
SensApi.dll
SENS Connectivity API DLL
6.0.6000.16386
False
False
False
False
False
NETAPI32.dll
C:\Windows\system32\NETAPI32.dll
NetApi32.DLL
NetApi32.DLL
Net Win32 API DLL
6.0.6002.18005
False
False
False
False
False
Cabinet.dll
C:\Windows\system32\Cabinet.dll
cabinet.dll
cabinet.dll
Microsoft® Cabinet File API
6.0.6001.18000
False
False
False
False
False
System.Design.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\System.Design\8269de7b5d0f6f37cb5349088db5fc2d\System.Design.ni.dll
System.Design.dll
System.Design.dll
.NET Framework
2.0.50727.4016
False
False
False
False
False
Accessibility.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\Accessibility\565d193dfea32659de5c814de5207abc\Accessibility.ni.dll
Accessibility.dll
Accessibility.dll
.NET Framework
2.0.50727.4016
False
False
False
False
False
jabber-net.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_32\jabber-net\b43e4c8d109b3dba33c92af1dae3e61c\jabber-net.ni.dll
jabber-net.dll
jabber-net.dll
2.1.3.760
Jabber-Net library
jabber-net
2.1.3.760
False
False
False
False
False
Language Neutral
HtmlInterop.ni.dll
