Help get this topic noticed by sharing it on
Twitter,
Facebook, or email.
Twitter,
Facebook, or email.
Is there any way to export contacts?
Is there any way to export contacts? A workaround such as emailing a contact card or syncing with gmail could be a solution too...
Nevermind, I figured it out! Tools > Contacts, then I can drag contacts into an email message to send as buisness cards!
It is also possible to drag the contacts into explorer and they will be saved into files. The files can then be dragged into eM Client back in the same way.
Then how do you export contacts for import into google?
Filip Navara, could you please explain to a "non professional" how to export the contacts? I just can't figure out how it works. The maximum I can get is on contact, even if I chose 10 or 100. Thanks.
Loading Profile...
EMPLOYEE
