IMAP issue = I have configure IMAP setting in eM Client, but for receiving new mails i need to restart the eM Client every time, kindly give us any solution.
Global Adress Book = Can we configure GAL in eM Client?
Help get this topic noticed by sharing it on
Twitter,
Facebook, or email.
Twitter,
Facebook, or email.
Does it report any error? What do the logs say (click on the status bar on the bottom of the window)?
Hi I think this may be related to my post titled (Mail Box message Limit)
I will explane please start emclient then select tools then operations when the window opens do you see operation that is not completing? Like syning a mail box folder if so that is what I am seeing as well. when a process is hung it will not get any new mail till a restart. What I found was if I deleted enough messages one by one it finished it operation when I got the message count down to 168. no fix yet that I know of. -
Sorry for opening up an old wound.
This could be related to the issue I am seeing, were I am getting failures during synchronization. I just checked the server and it shows 235572 messages, however the eM Client only shows 234552. So where did the other 1020 messages go? Same issue with the Junk mail; only 195 of 391 messages are displayed in the eM Client.
Error shows "An attempt to connect to (my user name) failed. This could be caused by temporary server unavailability or incorrect settings. Do you wan to check settings?"
Log shows "Cannot access a disposed object."
Logically, I must ask; If the object is "disposed", why does eM need to locate it?
Hope this helps point thing towards a resolution. -
I have the same issue as Luis, looks like no one care about this issue
Loading Profile...
EMPLOYEE
What's the resolution to this?
