Help get this topic noticed by sharing it on Twitter Twitter, Facebook Facebook, or email.
kerframil
Fine-grained font control & better defaults for Vista/7
I've very recently discovered - and am trialling - eM Client after being left increasingly in dismay by the direction Thunderbird has taken since version 3.0 and the state of 'alternative' desktop mail clients in general. Firstly, I'd like to say that this software is a breath of fresh air. I was immediately impressed by its coherent user interface, stellar IMAP performance and its Jabber/CalDAV support, allowing for straightforward integration with Google's services. In an era where I find myself increasingly perplexed by the UI design decisions made by developers, it's a testament to this application that there was very little I felt needed to be changed or tweaked.
That said, it does have a weakness which quickly developed into an irritation on my part. Under Tools > Settings Read > Preferred Style, there is only a single option for the "preferred font". This is not sufficiently fine-grained. I prefer for plain text content to employ a fixed width font and was pleased to see that it was allowed for. However, I think it is very important that the user be allowed to set the preferred font for text/html and text/plain MIME parts independently. As it stands, the preferred font is respected for HTML content but it appears to be hard coded to Courier New for plain text content. Worse, the font size is asserted for both which leads to a visually jarring imbalance in the appearance of either.
Furthermore, the default font choices throughout the application appear to be optimized for Windows XP. In my opinion, the defaults could be improved for Windows Vista and Windows 7. Ergo, I would propose the following simple changes:
  • The existing opton is labelled as Preferred font for HTML messages and constrained to influrence only HTML parts
  • An additional option labelled Preferred font for plain text messages is added and that this particular font be enforced if the Use preferred font for fixed-width plain text messages option is enabled (as opposed to disabled, as it would no longer make sense)
  • If the application detects that it is running on Vista, Windows Server 2008 or newer, the default for HTML is set to Calibri, 12pt upon first loading
  • If the application detects that it is running on Vista, Windows Server 2008 or newer, the default for plain text is set to Consolas, 10pt upon first loading
On a similar note, I think that the choice of Microsoft Sans Serif for some UI elements makes sense in XP, but reduces the overally legibility in newer versions of Windows. Therefore, I would also propose these changes:
If the application detects that it is running on Vista, Windows Server 2008 or newer then, upon first load, it should:
  • Default to Segoe UI, 9pt under Appearance > Mail
  • Default to Segoe UI, 9pt under Appearance > Calendar
  • Default to Segoe UI, 9pt under Appearance > Tasks
  • Default to Segoe UI, 9pt under Appearance > Contacts
  • Default to Segoe UI, 9pt under Appearance > Sidebar
The Groups font preferences are of lesser importance and seem fine as they are. Making these changes is not only concordant with UI trends, it makes the application feel rather more at home in Windows 7 and more pleasant to use.
5 people like
this idea
+1
Reply
