szlevi
sad I’m frustrated
Extremely slow at displaying messages...
...even with a moderate amount in my Inbox - about 13k messages - and it's truly maddening in the morning when I usually clear the spam from my boxes: each message takes about a sec to display in the bottom preview pane after I clicked on it...
...is it a bug or some design limitation? If the latter then are you guys sure eM is ready for corporate use?
5 people have
this problem
+1
Reply
  • Hi, it is certainly not normal. We don't experience that. Can you try to hide sidebar so we can exclude it here? What version of Internet Explorer do you have? Are these messages already downloaded (standard behaviour for IMAP is that messages are downloaded at the moment when first requested). Another issue may be your keyboard repeat rate. eM Client starts displaying message detail after keyboard repeat rate. This may differ a lot on different OS/hardware. On my notebook (and it is quite old notebook) messages (already downloaded) are displayed immediately.
  • (some HTML allowed)
    How does this make you feel?
    Add Image
    I'm
    e.g. indifferent, undecided, unconcerned sad, anxious, confused, frustrated happy, confident, thankful, excited kidding, amused, unsure, silly
  • szlevi
    Probably the message downloading part... but it's a local mail server and I'm the admin here and I never seen such slow (1+ sec) response... I'll 'tail' the logs later.
    Meanwhile I'd like to ask if eM is multicore-aware/multi-threaded? The UI sometimes seems to be frozen while doing something else eg. downloading new messages...
    Add Image
    I'm
  • szlevi
    sad I’m frustrated
    UPDATE: switched to Google Apps recently... didn't help.
    I tried downloading all my messages - well, it not only didn't help but God, it's AWFUL now.
    And what's worse is that it's probably irrelevant - it's slow as @ss even when I click on an already read item - a preview takes seconds, showing the Silverlight-styled circualr animation while loading the message...
    ... this client is quickly reaching the point of being useless (aka equal to that junk called Thunderbird 3.x).
    Add Image
    I'm
  • Hello,
    just to ensure, did you please try hiding the sidebar? To do so, go to Tools->Settings->Sidebar -> click radio button "Hidden sidebar" and restart eM Client.
    Also do you use Skype interoperability?
    And what version of Windows do you have?
    I am sorry to hear you are experiencing such issues with eM Client.
    Best Regards
    Add Image
    I'm
  • ptacek.pavel
    silly I’m curious
    Hey,
    couldn't it be just because of some maintenance of maild_data.dat? I have aprox. 1.5GB of e-mails there, but the data file is 2.5GB and slooowly is getting smaller.
    Now, in my case it propably was because of the fact, that I have migrated from that slow outlook 2003.. Since I'm using POP3 for everything (with mails stored on server coz of company policies), the process was as follows:
    1) Import into eM Client from outlook
    2) Leave the import as it is, set-up all accounts not to delete any messages from server
    3) Download all messages from all my mailboxes
    4) Delete everything from recieved inbox (hey, there would be duplicate e-mails...)
    5) Sort out the folders imported from outlook
    (yeah, i love local folders :-)
    now, the eM Client is slow, but still usable. The fact of above procedure is, that it created 3GB database file with e-mails - and than I deleted half of them. Now, when eM is running something is happening on my HDD big time and the datafile is getting smaller.
    So, I tried small test.. I backed up my database folder first. Then I downloaded sqlite3.exe and ran a vacuum command on the mail_data.dat -> result was 1.5GB mail_data.dat file (it was done within 5 minutes). When I launched eM afterwards, it was fast like hell!
    However, since vacuum (as per my understanding) might reset some of the options in the database and I don't know how precisely sqlite works, i loaded the backup back and am just leaving the eM running with high priority even when i'm not using it. Simply, i have no idea what you guys are doing with the database inside of em and i love my e-mails too much to be experimenting with the core one :-))
    So - couldn't this be a problem? If @szlevi is getting a lot of spam and quickly deleting it .. maybe there is a vacuum in the queue of sqlite which makes em slow to respond ... somehow.
    As I said - full vacuum (which requires another 1.5gb of disk space in my case) helped and solved the matter (but i'm too scared to live with the vacuumed database though). the auto-vacuum or some other used procedure might not use that much of disk space (really - it just slowly decreases the data file size).. but couldn't that be the cause of the slowness in this case? Deleted, but still physically present e-mails?
    It's just an idea, don't beat me up..
    P.S.: I disabled sidebar and skype interpobality in my case, and file is still getting smaller at a snail rate
    P.S.2: i found out about vacuum and used command from this site: http://en.kioskea.net/faq/2285-compac... (nobody try it! for sake of your mails..)
    Add Image
    I'm
  • ptacek.pavel
    happy I’m incredibly excited!
    Ha! Thanks to Gabriele Staron this command fixed my problem:
    "C:\Program Files\eM Client\DbRepair.exe" /forcerebuild
    (found it in different topic)
    Just run the above command should you have speed issues with eM - it will cleanup and rebuild your database and should fix problem :-)
    Thanks Gabriele!!
    Add Image
    I'm
  • Hugh Johnson
    I have a similar issue. When I first click on the email, there is a quick flash of the images. Then the images disappear and the round timer (same function as the Windows hourglass) starts. Several seconds later the images display again. Does anyone have this problem? Any ideas how to fix this?
    Thanks
    Add Image
    I'm
  • Rod Bristol
    sad
    For most messages, including those with heavy HTML content, eM Client works just fine. However, for messages from "TheStreet" , I get the quick flash of the message, followed by a blank window and the "waiting" icon. Eventually, more than 10 seconds later, the message displays again. Displaying another message and returning to the offended one repeats the waiting sequence.
    Thanks.
    Add Image
    I'm
  • Hugh Johnson
    Thinking I would get better tech support, I bought eM Client. I also got the quick flash of the message, followed by a blank page and then the spinning circle icon. After a long wait with the circle spinning, the message would finally display. Tech support told me that the problem is my Internet Explorer which I do not believe. He also said there is nothing that can be done about it. I have a friend who installed eM Client on his very fast computer and the same problem occurred. In addition, I installed eM Client on a third computer and the same thing happened. I am surprised that users are simply accepting this as normal behavior. I became so fed up until I asked for and was given a refund.
    I really expected to get better customer support as I was a paying customer at the time. However, it didn't happen.
    Add Image
    I'm
  • EM Client is relaying on IE as rendering engine for its HTML, together using .NET framework as runtime. Not the best combination to use, but in my opinion it is limited by nature. This problem appears much more obvious on IMAP accounts compare to local. We can only wait for IMAP to mature on eM.
    Add Image
    I'm
